04-11-2020 05:38
04-11-2020 05:38
There used to be a button on the PC app (is it an app and not a program anymore?) that would trigger a sync. Now it seems to sync once a day at a time of it's own choosing. Have they removed the sync option deliberately? I wonder why?
04-13-2020 13:14 - edited 04-13-2020 13:16
That where I have been trying to take you. It doesn't say Connect until you download and install
Here is the link again to where you need to go to download it
Download for Windows store Pick the version you want to download
Wendy | CA | Moto G6 Android
04-11-2020 12:44 - edited 04-11-2020 12:45
Not quite sure I understand your question
You have never been able to sync on the computer unless you are talking about Fitbit connect. Which is a program on your computer. You just need to locate it
But in the App open it up tap on the Image of the Device. And you will see where to sync there
04-12-2020 05:51
04-12-2020 05:51
Thanks for your response.
I have the app set to All-Day Sync but it only seems to sync when it chooses, no rhyme or reason, about once a day. That doesn't sound like All-Day Sync. Or am I misinterpreting?
04-12-2020 06:02
04-12-2020 06:02
Also...
Where is the best place to get the Fitbit Connect software? Can't seem to find it on their site and I am wary of these squirrelly download sites?
Thanks again.
04-12-2020 22:26 - edited 04-12-2020 22:26
Windows store is squirrelly? Please Scroll down
04-13-2020 08:24
04-13-2020 08:24
Already have the Fitbit app. I thought somebody said that there is something else called Fitbit Connect?
04-14-2020 07:23
04-14-2020 07:23
Oops. Silly me! I was using the website on the PC and that does not control sync.
Thanks for your patient advice.
Seems like only one device can be connected to the Surge at a time.
