02-04-2017 13:36
02-04-2017 13:36
Can someone tell me if they were able to sync their CHarge 2 fitbit activity with their weight watchers app? It keeps telling me it currently does not support that device. Help
02-05-2017 22:13
02-05-2017 22:13
If you nwamt to connect yoir Fitbit account to your Weight Watchers account, you can gind info at www.fitbit.com/apps or at the pinned post https://community.fitbit.com/t5/Third-Party-Integrations/Third-Party-Apps-Informational-Post/td-p/14...
You might have noticed that I moved your non Charge2 related post to the Third-party app Forum. You see your Charge2 can only sync to your Fitbit account.
02-04-2017 13:44
02-04-2017 13:44
I just synced mine earlier this week.
02-04-2017 13:50
02-04-2017 13:50
I guess I need to figure out why it is not working 🙁
02-04-2017 19:53
02-04-2017 19:53
I also can not get charger 2 fitbit to sync with my weight watchers app?
02-05-2017 04:58
02-05-2017 04:58
Thank you! Now I don't feel that I'm crazy. Still trying but no success 😢 So entering my activity manually on WW app
02-05-2017 11:09
02-05-2017 11:09
Try uninstalling both apps, clearing browsing history in all of your browsers on your mobile device, shut the phone down- count to 15 then turn on phone, reinstall both apps and see if that fixes any glitches. Also check to see if your mobile device has any updates.
02-05-2017 21:51
02-05-2017 21:51
I tried this an it did not work, thanks for the suggestion
02-05-2017 22:13
02-05-2017 22:13
02-06-2017 05:16
02-06-2017 05:16
02-06-2017 08:00
02-06-2017 08:00
Thanks so much all it had to do with was I was using Internet Explorer switched to Fire Fox an it worked very easy
