02-16-2017 05:23
02-16-2017 05:23
I use Lose It! to track calories and I am having trouble syncing between the two apps, starting yesterday. I trouble shot the issue through the Lose it! app and was able to get it my activity from Fitbit, but my calorie consumption from the Lose it! app is still not showing up in my Fitbit app. Any suggestions?
02-18-2017 10:41
02-18-2017 10:41
It's nice to have you aboard @jaza_renee!
In order to sync your Fitbit account with Lose it!, the user must be a Premium LoseIt subscriber.
It hard to define what exactly syncs with Lose it as the API doesn't belong to Fitbit, but according to what I know of this integration, your Fitbit account sends calorie data only to LoseIt and LoseIt compares their estimate to the user's calorie burn from Fitbit and adjusts the user's calorie goal. On the contrary Lose it only sends logged food to Fitbit; so "Calories In" are not share from Fitbit to Lose It.
To connect the two accounts, please do the following:
Hope this helps!
Best Answer02-22-2017 10:25
02-22-2017 10:25
02-23-2017 05:00 - edited 02-23-2017 05:00
Thanks for joining us here @AG819! If you've followed the steps I posted above, I'd recommend taking a look directly to Not sure if your Fitbit data is syncing to Lose it!? Troubleshooting Tips' article from Lose it!.
Hopefully that works for you!
Best Answer05-08-2017 15:56
05-08-2017 15:56
I am a Premium LoseIt subscriber, still no data sync regarding food.
05-08-2017 17:39
05-08-2017 17:39
Hello @Aristotle did you gollow the tips in the article @MarreFitbit posted above?
If it still isn't working then please reach out to lose-it. Third party apps are responsible for their connection, fitbit only provides the doorway.
Best Answer07-29-2018 13:53
07-29-2018 13:53
I am working a 10k step day goal on my Charge 2. Want this effort synced with my Lose It app.
07-29-2018 20:21
07-29-2018 20:21
Hello @leeper03 may I ask if your having problems and what they might be, or are you looking for the instructions, found above, that explain how to sync up the two accounts
Best Answer07-30-2018 02:42
07-30-2018 02:42
Best Answer08-02-2018 06:30
08-02-2018 06:30
I just got a new phone, previously one did not need to be a premium subscriber to link Fitbit and lose it. This stinks.
Best Answer08-02-2018 14:07
08-02-2018 14:07
Changing the phone should not affect the Fitbit connection to Lose It.
The two accounts transfer data through the internet. Your Fitbit account with your Lose It account. The truth is you don't even need a phone for this .
As mentioned many times, the best we can suggest is to go to your applications list, revoke Lose It and reconnect.
If this doesn't work, contact Lose It, third parties are in control, not Fitbit, of their link and will dictate what will sync .
Best Answer08-02-2018 14:12
08-02-2018 14:12
Best Answer09-02-2018 14:47
09-02-2018 14:47
I’m having the same problem, and I followed the steps.
Best Answer09-02-2018 15:03
09-02-2018 15:03
Best Answer09-02-2018 15:14
09-02-2018 15:14
@Kellyp513 what did Lose-it say when you're u contacted them?
Third party sights are responsible for their own linkup.
Best Answer09-03-2018 16:32
09-03-2018 16:32
Update: Everything began to sync correctly today.
Best Answer01-09-2019 15:46
01-09-2019 15:46
I followed the exact instructions above and everything is syncing besides my food input on the Lose It app. I am a premium member and still nothing.
Best Answer01-09-2019 15:49
01-09-2019 15:49
Best Answer01-09-2019 15:51
01-09-2019 15:51
Best Answer01-09-2019 21:54
01-09-2019 21:54
@MWest1002 what was it that Lose+It requires you to try?
Please remember that Loose-It is responsible for their connection.
