05-18-2019 10:48 - last edited on 05-19-2019 05:56 by LanuzaFitbit
Hi,
i have made a web app that upload Fitbit NON GPS activities to Strava.
If you want to use go to https://www.fittostrava.com
At this moment it's a first release, so tell me if it works fine.
Thank you.
Marco
10-09-2020 13:25
10-09-2020 13:25
Thank you! Also shows wrong time for me on strava. Shows as 1 hour earlier than actually was. Is correct on your app though.... Thoughts?
10-19-2020 08:52
10-19-2020 08:52
This app worked perfectly fine, transferring non-GPS activities into Strava, but it stopped working last week. I see them in your app, but when try to Export to Strava, they don't. Hope this can get fixed. Thanks.
10-20-2020 04:00
10-20-2020 04:00
Hey, your web app has been working great. But not syncing today. Just checking if there's a problem? Thanks
10-20-2020 17:09
10-20-2020 17:09
Having the same problem, only noticed it last night. Fingers crossed it gets fixed soon 🙂
11-19-2020 11:43
11-19-2020 11:43
Hi. Tried the utility a week ago and it seemed to work. Now it does not.
12-30-2020 13:58
12-30-2020 13:58
I have tried it but it doesn't seem to work.
Activities are listed on your site but not transferred to Strava when exported.
Hope it will be fixed.
02-10-2021 04:36
02-10-2021 04:36
Found your website today.
Seems to work well, thanks for taking the time. 😊
02-28-2021 04:09
02-28-2021 04:09
Is the app having issues again? It says "Activity uploaded to Strava!" but nothing shows up for weight training non-gas activity :(.
Advise appreciated!
02-28-2021 07:45
02-28-2021 07:45
Hi Marco, I'm going to add to the requests here for you to open source your code so we can be sure you're not doing anything else with our data. I'd also be happy to contribute bug fixes (if you're interested in that.)
03-05-2021 22:23
03-05-2021 22:23
Hi Marco, some issue with syncing to Strava since 2-3 says
03-07-2021 13:48
03-07-2021 13:48
Works very well!
If only... if only it would be able to match the data already @ Strava, to add the BPM afterwards to the activity, that would be the best. But nevertheless, it does it's job.
Tbh, making code open source would give you a much bigger audience, and more people will trust your application more. Still, good job!
04-15-2021 23:31
04-15-2021 23:31
Hi
Anyone else having issues with uploads? FittoStrava confirms upload, however no workout appears on Strava.
TIA
07-13-2021 03:50
07-13-2021 03:50
Just found this and it's awesome! Donated right away. I'm also all for making it open source on GitHub, please do it, this ensures it will work forever.
07-16-2021 12:44
07-16-2021 12:44
Hi,
Few days ago i forgot to track my activity so I upload it manually in the Fitbit App.
Is it normal FitToStrava doesn't see that activity? I only van see the activities I started on my Fitbit-device and synced to the app.
Grtz
Naomi
08-14-2021 14:32
08-14-2021 14:32
I have the same issue also.
11-06-2021 10:52
11-06-2021 10:52
I have also the same problem
12-17-2021 20:55
12-17-2021 20:55
Thank you @shppotta ! This is wonderful. Will support to keep the web app running!
01-03-2022 16:24
01-03-2022 16:24
So I know I'm being greedy but I usually forget to actually do the sync. Is there any way to make this somewhat automatic? I've switched from outdoor running to a treadmill for medical reasons, and I like to sync to Strava to do things like warm me about how many kms my shoes have done. I'm wondering if there might be a way to do a scheduled transfer of specifically new treadmill data, for example.
01-05-2022 07:44
01-05-2022 07:44
It doesn't seem to Read Yoga activity from my Fitbit. Is that expected?
05-11-2022 03:46
05-11-2022 03:46
The webapp worked fine for many days but gives me errors message now.
Is there a limited numer of time that I can use it?
