10-03-2015
00:02
07:44
Mcore
10-03-2015
00:02
07:44
Mcore
Hi Guys
I am about to purchase a Charge HR. Currently i am using Map my Run to ..... Map my runs lol. I was wondering if syncing this app with my fitbit account is worthwhile? Im struggling to see if it will give me anymore useful info that the FitBit app and band will not. GPS is not really a concern as long as i can map how far and how fast i have run.
Cheers Chris
Moderator edit: Updated subject for clarity.
@chrisd575 It's nice to see that the Community is growing! I haven't used MapMyRun but I can totally share with you what syncs between Fitbit and MapMyRun. Fitbit will sync distance and calories to MapMyRun but MapMyRun won't sync data to Fitbit.
Hope this helps you to take the best decision. ![]()
@MikeTSteele It's great to have you here! Fitbit will sync distance and calories burned to MapMyRun. The data should be updated each time your tracker syncs. What are you seeing that's not syncing?
Also, there was a change on the way they synced you may want to check this post posted by @AndrewFitbit for more information.
Hope this helps. Let me know how it goes.
@MikeTSteele That sounds about right...activities/workouts don't sync over to MapMyRun. Same thing goes for MyFitnessPal.
You can check out my posts linked below for more info on the two integrations. 🙂
