05-11-2015
13:27
10:36
05-11-2015
13:27
10:36
Moderator Edit: We are aware that Weight Watchers is experiencing technical issues which may prevent proper syncing. This issue is on the Weight Watchers side, and we recommend that any affected customers contact their Support Team.
My fitbit charge stopped working with my weight watchers app, so I disconnected it from my app. Now I'm trying to sync it again and everytime I try i get this message:
{"code":403,"message":"Forbidden","errors":"Bad request"}
Anyone have any ideas on how I can get it to sync?
10-20-2015 05:41
10-20-2015 05:41
10-20-2015 06:25
10-20-2015 06:25
Hi all,
Since the latest update to Surge, there appears to be syncing issues with the Weight Watchers app / program and the accruing of WW Activity points. Are there any other WW users out there experiencing the same. This used to work ok, but is now extremely sluggish (i.e. points update 1-2 days after the activity / steps, if at all).
Thanks
Best Answer10-20-2015 08:28
10-20-2015 08:28
I didn't realize that fitbit and weight watcher could sync. I just set it up.
Best Answer10-20-2015 08:46
10-20-2015 08:46
I set this up but it does not appear to be working. It is suppose to take info from fitbit and send it to ww, correct??
Best Answer10-20-2015 09:12
10-20-2015 09:12
Best Answer10-20-2015 09:20
10-20-2015 09:20
Best Answer10-20-2015 09:28 - edited 10-20-2015 09:29
Hi @mbcdownes
Moved your post from the One to the Third-Party Integrations section to increase the chance of getting a solution.
Wishing a wonderful evening
Best Answer10-20-2015 09:48
10-20-2015 09:48
Does it translate fitbit activity into ww activity points or do you enter your activity into ww? My question, which way is the transfer.
Best Answer10-20-2015 10:54
10-20-2015 10:54
Best Answer10-20-2015 11:49
10-20-2015 11:49
What happens is, Fitbit sends the data about your activity to Weight Watchers, and Weight Watchers converts it to points.
Best Answer10-20-2015 11:50
10-20-2015 11:50
There seems to be a problem over at Weight Wathcers, a lot of people are not able to sync teir Fitbit accounts with Weight Watchers right now.
Best Answer10-20-2015 15:04 - edited 10-20-2015 15:07
Generally this is the case, since Fitbit does not send data to third party apps, but allows them to retrieve your data from your account.
@songbird1329 wrote:There seems to be a problem over at Weight Wathcers, a lot of people are not able to sync teir Fitbit accounts with Weight Watchers right now.
In general if it is on Fitbits side then every all that wants to use the data should be affected. If only one app is handing problems, chances are in their interstate to your data.
Has anyone contacted WW yet? They might be able to clarify what's happening.
Best Answer10-20-2015 22:42
10-20-2015 22:42
Best Answer10-21-2015 10:45
10-21-2015 10:45
@mbrett Thanks for your note. This topic was initially intended to discuss an outage with the Weight Watchers integration earlier this year. We are aware that Weight Watchers is once again experiencing connectivity issues, and they have stated that they are working to resolve this. I'm going to go ahead and close this thread to prevent further off-topic discussion. If you have more questions about Weight Watchers connectivity, the best place for them is Weight Watchers support forum.
