05-11-2015
13:27
10:36
05-11-2015
13:27
10:36
Moderator Edit: We are aware that Weight Watchers is experiencing technical issues which may prevent proper syncing. This issue is on the Weight Watchers side, and we recommend that any affected customers contact their Support Team.
My fitbit charge stopped working with my weight watchers app, so I disconnected it from my app. Now I'm trying to sync it again and everytime I try i get this message:
{"code":403,"message":"Forbidden","errors":"Bad request"}
Anyone have any ideas on how I can get it to sync?
05-19-2015 08:55
05-19-2015 08:55
Sunday I had a regular walking day and my sync never really worked. It "back synced" and gave me 7n APs. Monday, I walked a wee bit more than normal but it logged 24 activity points! As you can imagine, I know this is an error. I contacted the WW help desk and they acknowledged the issue but have no timeline on the solution.
Best Answer05-19-2015 09:10
05-19-2015 09:10
05-19-2015 09:35
05-19-2015 09:35
Best Answer05-19-2015 09:48
05-19-2015 09:48
Best Answer05-19-2015 09:58
05-19-2015 09:58
All my Fitbit Activity points have gone as well!! Must be a problem with WW.
Best Answer05-19-2015 10:28
05-19-2015 10:28
Its a weight Watchers problem. You should contact them.
Many people are complaining about this over on the WW boards. So I would look for a resolution there.
Wendy | CA | Moto G6 Android
05-19-2015 10:34
05-19-2015 10:34
10:37
08:38
05-19-2015
10:37
08:38
I apologize on their behalf for the inconvenience!
05-24-2015 17:47
05-24-2015 17:47
05-26-2015 04:30
05-26-2015 04:30
I am having an issue where AP are not being calculated correctly. I tried CHAT and they were totally unhelpful. I then contacted tech support on Sunday and the following email was delivered this morning:
Dear Marge,
Thank you for contacting Weight Watchers. My name is Rona and I will be happy to assist you with your eTools account. I apologize for any inconvenience that we may have caused you with your fitbit device.
Fitbit is not calculating activity PointsPlus / ProPoints values correctly. A fix has since been devised and is being released later today for all websites.
We are pleased to share that any incorrect values currently showing on our trackers will be adjusted following this fix.Weight Watchers is committed with your success. If you have any other questions or concerns, please reply directly to this email so we can further assist you.
Thank you for contacting Weight Watchers. I wish you the best of luck with your weight loss journey. I hope you have a great day.
Sincerely, Rona Customer Service Associate Weight Watchers International www.weightwatchers.com
Best Answer05-29-2015 15:16
05-29-2015 15:16
I also disallowed it in my programs trying to reset it and now i cant get it to ask me to sync with my ww app again. help please
Best Answer07-02-2015 11:14
07-02-2015 11:14
I also revoked access to the WW program and am now trying to set it up to sync again, but no luck. Is there a token or something that needs to be reset? I've tried calling ww support (4 times so far) and one time to FitBit, but still no resolution.
Best Answer08-16-2015 22:03
08-16-2015 22:03
My fitbit account isn't giving me points for my activity, i walked 5000 steps today and I didn't get any points for it. I havent been getting any points at all. I'm getting very fustrated and mad that I waisted my money on this thing.
Best Answer08-17-2015 05:05
08-17-2015 05:05
I usually don't see AP for steps until I hit around 5,200
Best Answer08-21-2015 06:32
08-21-2015 06:32
Best Answer08-21-2015 06:53
08-21-2015 06:53
Best Answer10-17-2015 06:22
10-17-2015 06:22
09:01
08:38
10-19-2015
09:01
08:38
@Pottermom Thanks for stopping by! I would like you to confirm that you're doing this procedure. What error are you getting?
Let me know how it goes.
Best Answer10-19-2015 12:17
10-19-2015 12:17
Best Answer10-20-2015 02:29
10-20-2015 02:29
Hi all,
Since the latest update to Surge, there appears to be syncing issues with the Weight Watchers app / program and the accruing of WW Activity points. Are there any other WW users out there experiencing the same. This used to work ok, but is now extremely sluggish (i.e. points update 1-2 days after the activity / steps, if at all).
Thanks
