11-09-2024
02:36
09:40
LizzyFitbit
11-09-2024
02:36
09:40
LizzyFitbit
Since yesterday the sync between Fitbit and MyFitnessPal is one day out, I.e. MyFitnessPal shows yesterday’s Fitbit steps for today. My wife has started with exactly the same issue (we both use Fitbit and MyFitnessPal over IOS). Any suggestions how to solve this issue appreciated.
Best Answer11-09-2024 10:18
11-09-2024 10:18
I have noticed that the steps within Myfitnesspal are much higher than in Fitbit. My steps in the fitbit app match my watch, but something is inflating them when they are sent to Myfitnesspal. Calorie adjustment is also not coming through
11-09-2024 10:28
11-09-2024 10:28
Similar problems. Cals 0, steps way off
11-09-2024 15:59
11-09-2024 16:47
11-09-2024 16:47
Would be nice to have a response as to when it will be resolved
11-09-2024 23:14
11-09-2024 23:14
My steps issue appears to have now resolved itself (same for my wife) with no action required by myself.
Best Answer11-10-2024 03:12
11-10-2024 03:12
My issue continues. Frustrating
11-10-2024 03:23
11-10-2024 03:23
I also have this problem. I deleted the duplicated exercise calories, disconnected and reconnected Fitbit as a connected app in MFP, logged out of MFP, updated MFP, and rebooted both my watch and my phone. Nothing has solved the issue; MFP is still not receiving any calorie updates from Fitbit's servers.
11-10-2024 04:03
11-10-2024 04:03
11-10-2024 06:12
11-10-2024 06:12
Im also experiencing this issue!
11-10-2024 09:49
11-10-2024 09:49
Me too since Thursday. Nothing has fixed it
11-10-2024 10:37
11-10-2024 10:37
11-12-2024 12:12
11-12-2024 12:12
I have just received this update from MyFitnessPal Support.
Hello,
Thank you for taking the time to contact us and for bringing this to our attention. We are aware of the problem with Fitbit steps syncing to the incorrect day, and are currently working on a resolution.
We hope to have a fix in place as soon as possible. Please accept our sincerest apologies for any inconvenience this may have caused. We appreciate your patience and understanding.
Best regards,
Hensen
11-12-2024 12:55
11-12-2024 12:55
Best Answer11-13-2024 12:13
11-13-2024 12:13
I’m seeing the same thing. Today it shows 11000+ steps with a -2 for a calorie adjustment. Actual as of this writing is 4900+.
11-13-2024 23:02
11-13-2024 23:02
I’m seeing the same thing, even after I disconnect the apps from each other on both sides it still shows me totally incorrect data
11-14-2024 21:00
11-14-2024 21:00
Mine is no longer adding steps and calories burned. It actually is stuck at 29k steps (0 calories burned though) which is what i did several days ago. I have done everything in the world to correct it. They have done something with an update to mess something up.
11-17-2024 13:31
11-17-2024 13:31
I had the same problem on 11/13. Sent a report to Tech Support and got an email with instructions. Followed them and FitBit synced the current step and calorie adjustment data but it took a few hours to do so. The problem came back two days later so I tried the same fix but it failed. Guess I'll just have to wait for MFP to fix whatever the issue is.
11-17-2024 14:23
11-17-2024 14:23
11-19-2024 16:15
11-19-2024 16:15
MFP has finally listed it as an outage and mentions Fitbit confirmed the issue is on their (Fitbit's) end.
https://support.myfitnesspal.com/hc/en-us/articles/360032625231-Known-Issues-Integration-Partners
Fitbit has yet to post an outage for it despite it being over a week and a half since it started.
