01-03-2018
14:07
04:48
RobertoME
01-03-2018
14:07
04:48
RobertoME
I would like to sync my weight/bmi/fat% to my fitbit account/dashboard. Maybe the other way around also the steps from fitbit into the nokia health mate app.
anyone any idea where to start? All the links in other topics and the help pages lead to 404 pages, for example: https://help.fitbit.com/articles/en_US/Help_article/1286/?l=en_US&c=Topics%3AX3rd_Party_Integration&...
any help is greatly appreciated!
cheers,
tom
Moderator Edit: Updated Subject For Clarity.
Best Answer02-06-2019 12:12
02-06-2019 12:12
@GrandOak on November I upgraded my app, and it work properly.
This thread is just full of troll..
Best Answer02-06-2019 12:30
02-06-2019 12:30
Best Answer02-06-2019 12:39 - edited 02-06-2019 12:43
I am a new user who tried to link with a Withings Body+ in January when I got the scale, and I got an authentication error. I bought the scale because the FitBit site had this Wizzard and a quick search had the forums shown the issues "solved" which is misleasing
However, others have reported earlier, it nowauthenticates me and then lists my Withings Profile which i can select. The when i click "Next" I get the error below.
So work seems to be taking place and it is encouraging. @KateFitbit I appreciate your effort and the update and so posting this to help with your testing.
Looking forward to having this feature working soon
John
02-06-2019 17:29
02-06-2019 17:29
Hello,
My account started syncing again as of today, I would say the issue is fixed. Maybe try the process again?
Regards!
Best Answer02-06-2019 17:39
02-06-2019 17:39
Nope, I just picked up a nokia/withings body+ and I'm also getting an unknown error after I pick my profile name. I hope it gets resolved soon too because I can't seem to catch a break with this health tech stuff. I had an older weight guru scale that you had to scan a barcode with your phone every time you wanted to sync. Now I finally upgrade my scale and now I don't have to scan it, but this one currently won't connect with the Fitbit system. The ifttt app only will do weight and not the other stats. So I guess I'll be currently punching them in manually, or using myfitnesspal as my main hub instead.
Best Answer02-06-2019 17:40
02-06-2019 17:40
Robin, do you think people would post without trying again given it takes about 5 seconds to run that connection wizard?! All new users can authenticate but then get the error "Cannot link Withings profile at this time. Withings server returned the following error: Unknown status code" when we try to select a profile.
It is astounding to me (a software developer) that Fitbit can take more than 2 months to get this simple issue fixed. Fitbit were given notice by Nokia/Withings long before they changed their authentication API, see https://developer.withings.com/oauth2/release.html. Fitbit apparently ignored this completely and after complaints around the web have only recently hacked something up to now allow us to authenticate, but then fail immediately with the error I state above.
02-06-2019 17:57 - edited 02-06-2019 17:59
Dear Mark81,
Just because for your (unspecified) situation an update worked unilaterally, please refrain from taking the lowest road available and branding other users with continuing issues (like myself) as trolls. Because it just makes you look like an arse.
02-06-2019 18:24
02-06-2019 18:24
02-07-2019 02:16
02-07-2019 02:16
Hi there, both me and my wife have been using the Withings scales linked to our Fitbit accounts for years now without issue, then they stopped syncing recently. I unlinked my account, and now cannot re-link due to the 'unknown' error after selecting my profile name. But my wife's data is now coming through again ok (as of this morning) without her doing anything!
It looks like someone is currently tweaking something behind the scenes..
03:16
07:31
LanuzaFitbit
02-07-2019
03:16
07:31
LanuzaFitbit
It's only fixed for people who previously had sync set up -- "new" users
get an error when we try to register. If you were to unregister and try to
re-register, I think you'd find you cannot do so.
Regards,
Moderator edit: Removed personal info
02-07-2019 04:26
02-07-2019 04:26
Exactly! Unfortunately i tried to disconnect withings from fitbit when it all startet. I thought maybe that would fix the issue. But now I get the same error message again and again every time I try to connect both platforms.
So not really solved yet...
Best Answer02-07-2019 07:34
02-07-2019 07:34
Hello everyone!
Thanks for taking the time to share your experiences on the matter.
As mentioned before, our team is looking into this situation and we will let everyone know as soon as we have any news.
In the meantime I'd like to ask for other users to confirm if the connection is working on their end. As @lmgray mentioned in this post, it seems like users that already had their accounts connected and didn't disconnect them are getting the functionality back.
Feel free to reach out with any further questions.
Best Answer02-07-2019 07:43
02-07-2019 07:43
It sounds like it is working for people who had it setup before. I purchased mine in the last month or so and have never been able to set it up and I still can not. Still getting an error "Cannot link Withings profile at this time. Withings server returned the following error: Unknown status code" after selecting the profile.
02-07-2019 08:58
02-07-2019 08:58
User since September, sync was fine... Tried to disconnect and reconnect to sort things out, now I also cannot reconnect.
Best Answer02-07-2019 21:18
02-07-2019 21:18
Best Answer02-08-2019 10:24 - edited 02-08-2019 10:25
I, just like a few of the others, have moved one step closer. The integration proceeds past the authorization step and actually reads my Withings/Healthmate profiles. When I select my profile it returns the "unknown" error. Progress, I suppose...very slow progress, but progress.
02-09-2019 00:46
02-09-2019 00:46
Withings to Fitbit alternative web integration:
02-09-2019 01:48
02-09-2019 01:48
Mark`s Solution works awesome and really fast. What a feeling to not have to put my weight and fat data manually into the app...welcome to 2019 😄
Great Work, thanks Mark!
02-09-2019 03:34
02-09-2019 03:34
Ridiculous price to pay for a sync
02-10-2019 12:24
02-10-2019 12:24
We already paid for both the scale and the FitBit - we shouldn't need a 3rd app just to transfer data.
