01-03-2018
14:07
04:48
RobertoME
01-03-2018
14:07
04:48
RobertoME
I would like to sync my weight/bmi/fat% to my fitbit account/dashboard. Maybe the other way around also the steps from fitbit into the nokia health mate app.
anyone any idea where to start? All the links in other topics and the help pages lead to 404 pages, for example: https://help.fitbit.com/articles/en_US/Help_article/1286/?l=en_US&c=Topics%3AX3rd_Party_Integration&...
any help is greatly appreciated!
cheers,
tom
Moderator Edit: Updated Subject For Clarity.
Best Answer01-25-2019 04:37
01-25-2019 04:37
Best Answer01-25-2019 05:41
01-25-2019 05:41
@GrandOak I think you misunderstood me, what I meant was:
My mother language is Italian, and sorry, but my English is quite limited.
I hope I better expressed myself. Have a nice day and Best Regards.
Best Answer01-27-2019 05:10
01-27-2019 05:10
Not sure how this is considered an "Accepted Solution" -- still not working...
01-27-2019 13:20
01-27-2019 13:20
@lmgray wrote:Not sure how this is considered an "Accepted Solution" -- still not working...
- Unable to authenticate Withings user. Withings server returned the following error: Unknown status code.
Maybe if you would have read any of the last five pages, you would know....
The solution was working till November 30th when something changed and now it's not working unless you use a 3rd party or if you set it up before November 30th.
01-28-2019 08:41
01-28-2019 08:41
Hello everyone.
We understand that this situation can be frustrating.
As mentioned before, at this moment there aren't any updates on the matter. Whenever there are any news to share with everyone we'll be letting everyone know.
Let me know if there is anything else that we can help out with.
Best Answer01-29-2019 10:29
01-29-2019 10:29
I used https://www.fitnesssyncer.com/ to link my Fitbit and Healthmate accounts. Now my weight and body fat shows up in the Fitbit app! Weight history from the Body+ scale also shows up.
01-29-2019 10:37
01-29-2019 10:37
@MichaelTapp wrote:I used https://www.fitnesssyncer.com/ to link my Fitbit and Healthmate accounts. Now my weight and body fat shows up in the Fitbit app! Weight history from the Body+ scale also shows up.
Oh, that is good to know! Anyone else want to try using fitnessyncer.com and confirm that it works? If it does, I'll update the "Solved Solution" to include this website for people trying to figure out workarounds till this gets fixed.
Thanks! 🙂
01-29-2019 12:48
01-29-2019 12:48
Don’t you think this will be solved when Fitbit fixes the integration with Withings? They even have a webpage to link accounts. Using a 3rd party is not a solve.
01-29-2019 13:21
01-29-2019 13:21
Hey Mark, I watched the videos from your software. Can you say if the software can sync automatically? Or do I need to sync all data manually?
And if it works automatically do I need to have the desktop App open, running and connected to the internet or does it work through the cloud on autopilot?
Thanks 🙂
Best Answer01-29-2019 13:25
01-29-2019 13:25
I can't seem to find any indication that Fitbit is working to fix it. Can someone point me to where Fitbit has stated they are trying to fix this issue.
My original Withings scale has been syncing with Fitbit for over 7 years (Jan. 2012 until now) and stopped syncing over the weekend. Seems pretty convenient for Fitbit that the quick and easy solution would be buying an Aria scale.
01-29-2019 16:39
01-29-2019 16:39
Hi @SunsetRunner, the app work manually.
Best Answer01-29-2019 18:50
01-29-2019 18:50
Best Answer01-29-2019 18:53
01-29-2019 18:53
Best Answer01-29-2019 19:12
01-29-2019 19:12
Also IFTT still only synch weight but not fat. Really a pity that it takes soooooo long to fix this issue.
Best Answer01-30-2019 00:11
01-30-2019 00:11
Best Answer01-30-2019 06:41
01-30-2019 06:41
Btw, syching on FitnessSyncher isn't automatic. It syncs overnight. However you can sync it manually through their Android app.
Btw, Withings saying this scale syncs with Fitbit is now false advertising.
Best Answer01-30-2019 12:33
01-30-2019 12:33
Same problem here. Cannot sync my fitbit and withings account. It's telling me to first fix the following issue: "Cannot link Withings profile at this time. Withings server returned the following error: Unknown status code." Still no actual fix? 😕
01-30-2019 13:31
01-30-2019 13:31
Seems there are some "progress".
While everytime I tried for the past month, I got an error on the authentication part, for the first time today, I was able to go to the profile selection.
Really hope it will be fixed soon.
Best Answer01-30-2019 14:22
01-30-2019 14:22
YES -- PROGRESS! We have several people in our Withings account so perhaps the "fix" has only been tested with single-user accounts? Someone with only one user able to report their experience? Since they're getting to my list of family members, it seems like they've gotten past the authentication step now. Not sure if it's Fitbit or Withings or (gasp) they're collaborating -- but at least we know someone is trying -- thanks whoever you are!
Please choose the user profile you want to be linked to your Fitbit account.
By linking your Withings profile you also grant Fitbit permission to change your Withings profile to public as necessary.
01-30-2019 21:34
01-30-2019 21:34
Single user. Got this error..
