04-15-2016 17:07
04-15-2016 17:07
If add excercise in MFP it will show up in Fitbit, but if I add it in Fitbit it doesn't show up in MFP.
For example I added 1hr cardio to Fitbit and it won't show up in MFP. Then on MFP I added 50min cardio as a test and can see that shows up in Fitbit. Also MFP isn't showing my steps tracked through Fitbit. Despite unchecking my iPhone as the device and selecting Fitbit multiple times it's still only tracking my steps through the phone not through my Fitbit. Why is it only syncing in one direction? (Surely that's not really a sync!) I've unlinked and relinked the apps multiple times, connected, disconnected, but it's made no difference.
Best Answer04-16-2016 16:16
04-16-2016 16:16
@superC That's because activities logged in Fitbit will not sync over to MyFitnessPal. There's a post here that elaborates a bit more on activity logging between the two apps.
As long as you've linked Fitbit and MFP, you should see steps from Fitbit in MFP (if you've synced of course). Make sure in the MFP app you go to More > Steps > Select 'Fitbit Tracker' > go back and hit 'Sync' at the bottom. Your steps will show up in 'Diary' under the 'Exercise' section, along with a calorie adjustment calculated by MFP.
04-16-2016 16:16
04-16-2016 16:16
05-24-2016 10:19
05-24-2016 10:19
Best Answer08-04-2016 10:21
08-04-2016 10:21
When I go to steps/add a device/Fitbit Tracker, the connect button is grayed out. How do I connect the two devices?
Best Answer08-04-2016 10:28
08-04-2016 10:28
@angs I'm guessing you're doing it through the mobile app? It might looked grayed out, but you should still be able to tap "Connect" to connect the two accounts. I just tried it with mine and it worked. If not, you can always try connecting Fitbit to MFP on a computer.
Best Answer08-04-2016 13:10
08-04-2016 13:10
Best Answer08-05-2016 07:53
08-05-2016 07:53
09-13-2018 00:24
09-13-2018 00:24
I am having issues with the account linkage. I had a MFP profile years ago but forgot the account details so I set up a new account. I have tried to link the two again but to no avail. I have revoked all access on fitbit and then tried to set the connection up again and it appears in my fitbit linked accounts bit but the MFP doesn't acknowledge they are connected. Very frustrating !!
Best Answer09-13-2018 19:00
09-13-2018 19:00
So are you saying if I workout and select "weights" from the list of exercise options on my Blaze then it won't be recorded on MFP? And that the Fitbit adjustment listed is just from steps alone?
Because that is what I'm getting from your reply and the linked post
Best Answer09-17-2018 05:01
09-17-2018 05:01
Best Answer09-20-2018 09:59
09-20-2018 09:59
Hello @Channyboy326. Welcome to the Forums @SunsetRunner.
@SunsetRunner Thanks for trying to reconnect the apps before posting in here.
In that case I'd recommend that you reach out to MFP directly. Given that this integrations are developed by the third parties, they should be able to take a closer look at what is going on and help you out.
Let me know if there is anything else that I can help you out.
