@SunsetRunner Welcome to the Community! The reason why you're seeing a discrepancy between Fitbit and MapMyRun is because Fitbit will track your distance based in your walking and running stride length and MapMyRun will track the distance based in a GPS. Both apps has it's own way to track the information.
You don't need to activate the activity mode because your Charge HR will keep track of your information even though it's not in activity mode. This action will give you detailed information of what you've done during that period of time.
Note: MMR won't sync information to Fitbit.
Hope this helps.
Best AnswerYou say you have MMR linked to MFP. I'm not sure if MFP pulls the workouts from MMR, but I do know that MFP does not send any workouts to Fitbit. Therefore Fitbit never sees the data from MMR. Your Fitbit App does have the ability to track using your phones GPS.
I have the Fitbit charge 2 that has gps through the phone gps. When I did map my walk and looked at my dashboard they were off. Map my walk had my distance at 5 miles just for the walk and Fitbit has my whole day mileage at 3.62 . I went to the store this morning so that means that Fitbit counted just my walk even less than the 3.62 . Why is the difference so great? Does this have anything to do with the recent Fitbit update? Please help as I need to make sure I am calculating the correct number of miles. Also my steps don't match up on the map my walk and dashboard either. MMW has my walk at 9,200 and Fitbit has me 8,690 for the whole day.
I'm having the same problem. Map My Run measures my runs consistently 1/4 to 1/2 mile longer than my Fitbit Charge 2. I assume since MMR uses GPS it's more accurate, but even when I use the GPS feature of Fitbit it's still off.
It's great to have you here @Heatherayt! When you're using two different trackers to get the GPS results. The data will be different because each one uses its own algorithms to track data. You may want to check this article How accurate is GPS?.
Hope this helps.
I have the same exact issue. ... same gear also.
Best AnswerI'm in a fitness fat loss group on Facebook. They advocate using fitbit and I love mine. Today, however, I realised that map my walk notes many more steps than my fitbit. I've read the other comments and responses but I'm still confused. Which step counter is correct??
Best AnswerMap my walk does not count your steps. It measures the distance walked, divides the distance by the stride isers stride to guess at how many steps where taken.
Fitbit counts the steps then uses the users stride to guess at the distance walked.
I'm having the same issue whereas map my walk registers a greater distance than Fitbit while both apps are running.
I have a Fitbit Surge. I've seen a lot of comments here about the difference between Mapmyfitness and the Fitbit and they don't exactly add up. My Fitbit is connected to the GPS on my phone. Mapmyfitness is also connected to that. Both Mapmyfitness and Fitbit have height, stride, weight, etc... I don't get as big a discrepancy on milleage, but the discrepancy on steps is huge, and I'm pretty sure it's the Fitbit that is not accurate. here is why... no matter how I am moving, very short quick steps, long steps, etc... I get less than 2000 steps per mile, which should be near the average. If Fitbit is actually counting steps, it's also correcting that count in some way (possibly due to stride?) because even if I do very short quick steps for an entire mile, I get the same result as if I just run, or walk... Mapmyfitness seems a little bit high on steps, and if they are just taking GPS and calculating from the miles, that is off too. Today I used Mapmyfitness for about 4.87 miles - four running and 1 walking. Mapymyfitness logged a little over 14k steps. My Fitbit I've worn all day (and had set for run during the run) and it says I have not even gotten my 10k for the day. In fact, I regularly have to go 6-8 miles to get the daily minimum which just can't be even close to right... need to figure out what is wrong.
Best AnswerHello @bookwyrm55 your Surge does not connect to your phones GPS but has its own GPS built in.
As for mapmyrun it gets distance from the phones GPS then uses your stride to guess at the steps. MMR does not count steps.
The surge looks at the arm motions to count your steps.
Best AnswerWhat is your running stride? 2000 steps per mile is closer to what a walk, not a run, should be.
If your running and do 2000 steps per mile there is something wrong.
MMF does not count steps, it counts distance therefore we can not use the step count from MMF, which was calculated based on the stride setting.. IE: MMF takes an educated guess on the steps walked.
This thread is a little old but I’m having the same issue but all I care about is distance. I’m less focused on step count.
Why is my running distance on my Blaze so much lower than MMR?
I assume MMR is more accurate for distance. Is there any way to adjust Fitbit to show the accurate distances?
Best AnswerI just got the Charge 2 and the distance and pace is way off from my MMR - I would think that at least the distance would be the same?? My fitbit and MMR are linked, kinda of hard to see which one is a true one. I have a race this coming Saturday so that should be a real test to see which is more accurate I quess.
