04-21-2016 20:44
04-21-2016 20:44
My fitbit and myfitnesspal are not syncing together. I have tried everything... Even going and revoking access and resyncing them. What am I doing wrong?
04-22-2016
00:07
16:31
AndrewFitbit
04-22-2016
00:07
16:31
AndrewFitbit
Still an issue...Fitbit does not consistently sync with MY Fitness Pal.
Why?
04-22-2016 06:12
04-22-2016 06:12
Hey there @ppatterson! It great to see that you've visited the Fitbit Community!
Let me help you out, I recommend checking in both accounts that your email address is the same then try logging out from both apps and log back in and linked them again.
Let me know how it goes!
04-22-2016 12:02
04-22-2016 12:02
Noticed this morning that steps weren't being recorded in MFP from Fitbit, but that calorie burn was being recorded, then this afternoon, still no steps and now calorie burn is also missing. Either way sync is still broken between the two.
04-22-2016 12:05
04-22-2016 12:05
This problem started this morning for me as well. Was working fine yesterday. This morning steps were not syncing to MFP from fitbit but calorie burn was, then later in the day calorie burn wasn't syncing either. At this time, MFP isn't getting information from fitbit (or alternatively something is wrong with MFP's ability to interpret which seems to happen ALL the time).
04-22-2016 16:33
04-22-2016 16:33
@RPIJG @ppatterson I'm currently not having this issue with my account.
Sometimes my steps don't always update in MFP, so here's what I've done in the past:
1. Select the 'More' tab at the bottom
2. Go to 'Steps' and either choose your phone or select "Don't track steps"
3. Let MFP sync
4. After syncing, re-select Fitbit as your device
5. Go back to the 'More' tab, scroll down and select 'Sync'
Once synced, you should be able to see your steps by going to the 'Home' tab.
Hope this helps. 🙂
04-22-2016 18:03
04-22-2016 18:03
