08-07-2015
06:56
06:08
AngelaMa
08-07-2015
06:56
06:08
AngelaMa
I log all my activities via Strava and I want to keep doing that, but when I sync them with fitbit the actual steps get overwritten with estimated steps (usually about 500 per mile fewer)
Can I stop this happening? The heart rate data (which is probably more accurate than the fitbit) doesn't overwrite so I'm not suer why the steps would.
Best Answer08-09-2015 21:22
08-09-2015 21:22
Welcome to the Fitbit Community @gt79. It's great to have you here. I would recommend revoking the access between your Strava and Fitbit accounts and link them once again. This should settle everything up.
I have moved your post to the Third-Party Integrations board because is more related to this topic. Thanks for stopping by, see you around. ![]()
Best Answer08-10-2015 00:16
08-10-2015 00:16
Best Answer06-26-2016 20:53
06-26-2016 20:53
I am running into the same issue. Did the revoking/re-granting of permissions work?
Best Answer07-03-2016 03:43
07-03-2016 03:43
Yes it did work, but I've just noticed the same thing happening again, so will be trying it again.
Best Answer07-03-2016 07:47
07-03-2016 07:47
