08-06-2017 09:32
08-06-2017 09:32
Any tips on how to get the 2 to exchange data. I've linked the accounts.
If I wear the Alta Hr then the auto thing picks up a bike ride but doesn't send anything to Strava even though it's running.
If I don't wear it, then Strava does it's thing but sends nothing to Fitbit.
At the mo, I am adding my rides manually.
Not sure what the integration is doing ??
Best Answer08-06-2017 13:32
08-06-2017 13:32
For a Fitbit event to sync over to Strava, the event needs to be recorded with GPS. This means you will need to use the Mobile track on the app for the event to sync. Unfortunately the mobile track does not have a bike function.
You might want to add your vote.
Best Answer08-06-2017 14:23
08-06-2017 14:23
Ok and I have voted !!
Why doesn't a Strava event come across to the Fitbit app ?
