05-22-2018
09:31
10:14
05-22-2018
09:31
10:14
@Ewynn Welcome! It's nice to have you on board! Sorry to hear that you aren't seeing your Strava activities on your Fitbit app. I would like to clarify that manually logged activites on Strava won't transfer to Fitbit only the ones recorded with the app. You can try removing the app from Fitbit apps area and removing Fitbit from Strava and re-link them again. You can also check Strava's suggestions here. You can also read more about the integration here.
I also moved your post to the appropriate board.
Let me know how it goes!
Best AnswerI am having the same problem, have you managed to find a solution to this problem?
03-22-2019
18:35
10:14
03-22-2019
18:35
10:14
@DebbieMotty It's great to see that you've visited the Fitbit Community! Sorry to hear that you are having the same issue with your Strava activities and for the delay in my response. Did you try the suggestions in my previous post? There was an issue with the integration but Strava solve it so I wanted to know if you are still having issues with this?
I look forward to your reply.
