01-10-2016 07:05
01-10-2016 07:05
Best Answer01-12-2016 07:23
01-12-2016 07:23
@Wellsy A warm welcome to the Community! Yes, you can link Fitbit with Strava and your Fitbit activities will appear on Strava. Please follow this linking procedure, you need to follow the procedure using a computer.
No, the heart rate information won't link to Strava. Your Fitbit activities will now appear on Strava, and your runs and rides tracked by Strava will contribute to your Fitbit all-day stats.
Hope this helps. Let me know how it goes.
02-20-2016 10:50 - edited 02-20-2016 10:53
AndrewFitbit wrote:Only activities recorded with GPS data will be sent from Fitbit to Strava. Since you both have the Charge HR, you would need to utilize your phone's GPS to track the activity. This can be accomplished by using the MobileRun feature in the Fitbit app.
Thanks for the input @Wellsy! ![]()
@pbarring Your activities don't have GPS data, that's why you're not seeing them show up in Strava. You'll need to record the activity through the Fitbit app.
@Maso Looks like you're also using MyFitnessPal, careful when chaining multiple apps together. Are you sure the activity you're looking at in Strava came from Fitbit? Might want to try just using the Fitbit app to record your activity while wearing your Charge HR. Once the activity syncs over to Strava, you should be able to see the HR data.
01-12-2016 07:23
01-12-2016 07:23
01-12-2016 15:28
01-12-2016 15:28
01-12-2016 16:44
01-12-2016 16:44
@Wellsy I'm happy to hear that you were able to link Fitbit with Strava. I hope you can continue loving your Surge and discovering the great features it has
If you want to continue learning about your Surge, you can check the Product Manual. Hope I can continue seeing you around.
Best Answer02-10-2016 15:45
02-10-2016 15:45
So wait, no HR data back to Strava? This basically makes the charge HR useless for bike riding....
02-10-2016 16:01
02-10-2016 16:01
Hey @plaroche, welcome!
I think there might be some confusion here. Heart rate data will not sync from Strava to Fitbit; however, it will sync from Fitbit to Strava (when HR data is available). So if you have a Fitbit tracker that has HR and you track the activity through Fitbit, the heart rate data will sync over to Strava. I hope I explained that well enough. Let me know if anything needs clarification! ![]()
Best Answer02-11-2016 05:29
02-11-2016 05:29
K, so maybe someone nees to look at my account as no fitbit excersises have shown up in my strava account even though I have enabled it
Best Answer02-11-2016 06:20
02-11-2016 06:20
Hi There, I'm the same as @plaroche
I have a Charge HR but the Heart Rate collected in my fitbit bike actvities is not showing in my Strava actvities.
02-11-2016 11:05 - edited 02-11-2016 11:07
@plaroche @pbarring Sorry, I left out a key point in my explanation. ![]()
Hope that helps. ![]()
Best Answer02-11-2016 12:32
02-11-2016 12:32
Yup, already doing that. Used the iOS fitbit app. Did two activities yesterdy, fitbit shows them both in the app and web app as Outdoor Bike, with gps, hr etc, I have not seen them come through in Strave
Best Answer02-11-2016 12:58
02-11-2016 12:58
@plaroche Interesting. Could you take some screenshots showing the activity and the GPS data? If it has GPS data it should have synced over.
Best Answer02-11-2016 13:05
02-11-2016 13:05
In looking up screen shots for this it appears as if my mobile app had not synced (in tow days?) to web. It seems to have correct itself just now.
Odd, any tricks to ensure mobile app syncs up to your backend?
Best Answer02-11-2016 16:27
02-11-2016 16:27
@plaroche My only advice is to make sure you have a strong Internet connection after completing the MobileRun activity so that it can completely sync over. If you're using more than one app to track the same activity, that can potentially cause an issue.
Best Answer02-19-2016 20:09
02-19-2016 20:09
02-20-2016
00:54
09:53
AndrewFitbit
02-20-2016
00:54
09:53
AndrewFitbit
Hi there
I don't think the heart data is being sent to Strava. I haven't ever seen HR put into Strava via Fitbit. At least the mileage from Strava is being put into Fitbit.
I think as a future feature, it would increase Fitbit sales if heart data did appear in Strava. Think of all those cyclists who would no longer need to wear a chest monitor and could rely on just a tracker.
That maybe the rub though. Strava want cyclists to buy their monitor.
Kind regards PB
Apologies for shorthand, sent from my mobile
Best Answer02-20-2016 02:23
02-20-2016 02:23
Best Answer02-20-2016 10:50 - edited 02-20-2016 10:53
02-21-2016 01:39 - edited 02-21-2016 03:20
Thanks, you may be right. I changed some of my synced apps and I just got everyhting including HR mapped to Strava, but I think what's needed for most people is an app syncing guide for dummies. Most people have at least a few apps they use together. But as I see, you can end up with an endless loop of syncing if you're not careful and it's hard to know the optimum sequence.
Cheers for your quick reply though.
Best Answer05-15-2016 17:28
05-15-2016 17:28
This solution did not work for me; I was taken to the Fitbit dashboard, I was never asked to login to Strava.
Best Answer05-16-2016 09:39
05-16-2016 09:39
@Moebriley A warm welcome to the Community! I would like you to confirm that you're going to http://strava.fitbit.com/ and this will take you directly to connect both accounts.
To confirm both apps are already linked, go to your Fitbit Dashboard > settings > Applications >
you'll see "Fitbit Strava".
