07-11-2018 10:52 - last edited on 10-20-2018 12:11 by SelmaFitbit
Update 7/12/2018: We made some updates on our end. Please try again, note that old runs may not populate. If you are still experiencing this, we recommend unlinking the connection from both sides (Fitbit and Strava), then link the accounts again.
Update 7/11/2018: Please check out @GordonFitbit's post for the latest update.
Update 7/11/2018: Hi Everyone - We are currently investigating a few reports from users receiving an internal error message, error 500 when trying to sync with Fitbit. I'll post here once I learn more, thanks for calling this out and your patience.
Moderator edit: label
Actively managing your weight? Find accountability buddies on the Manage Weight board
07-01-2018 20:03
07-01-2018 20:03
I have linked fitbit to my strava account. My activities on strava are not coming over to fitbit. These activities are recorded on a third party GPS and uploaded to strava. Should this work? Any idea what I may be doing wrong?
07-04-2018 08:11
07-04-2018 08:11
Hi there @Barry_C, welcome aboard to the Fitbit Community and my apologies for the late response. I was reading your exercises upload from a third party GPS to Strava are not syncing to your Fitbit Dashboard.
I'm not sure if by uploading the information from other app, Strava is going to send the exercise to Fitbit. The way Strava works with your Fitbit Dashboard is the following:
If you are recording your exercise from Fitbit:
Have you noticed any activity synced as a manually logged activity in your exercise history. If there is one, it is possible this is coming from Strava.
See you later and hope this helps a bit.
07-04-2018 10:04
07-04-2018 10:04
@RobertoME Thanks for the reply. I had already read the FAQ so not much new info though. The activities aren't coming over, even as manually logged activities. Any suggestions on what I can do to debug the problem?
Thanks
07-04-2018 10:10 - edited 07-04-2018 10:10
I see, thanks for keeping me posted @Barry_C. Have you tried to use only strava to track your exercise, without the need of the third party GPS app?
Is the issue still persisting by doing this?
If the information is being transferred by using only Strava, then it is possible the information cannot be share if is coming from other third party app. However this is just a thought, that I would like to confirm.
I'll be looking forward to your response.
07-06-2018 07:28
07-06-2018 07:28
@RobertoME, I have had the opportunity to track exercise directly in the Strava app, the problem persists and I cannot sync from Strava. What else can I check? I am afraid there is a problem with my fitbit account.
07-06-2018 07:52
07-06-2018 07:52
I try to go to strava.fitbit.com follow the log in. Then sync with settings and it always gives an internal error message. When will the error be fixed?
07-10-2018 09:24
07-10-2018 09:24
My guess is that private Strava activities aren't synced to Fitbit. I'm experiencing a similar problem and this was the only possible answer I could think of.
07-10-2018 16:57
07-10-2018 16:57
None of my activities are private. I have confirmed activities sync from Fitbit to Strava but not the other way around.
07-11-2018 09:24
07-11-2018 09:24
I have the same problem. I can't sync with Strava
07-11-2018 10:47
07-11-2018 10:47
07-11-2018 14:45
07-11-2018 14:45
Hi everyone - We've made a change on our side. Would you please try again and let me know if you still cannot sync your data?
07-11-2018 15:48
07-11-2018 15:48
Hi @RobertoME. Today I did some interval training with GPS, on my Ionic. This is not syncing to Strava. My runs and cycles(rides) are syncing but this is not? Any reason for this?
The GPS data, HR, splits, impact calories etc are available in the Fitbit app.
07-11-2018 15:49
07-11-2018 15:49
Hi @SunsetRunner. When was the last time you tried to sync your data?
07-11-2018 23:40
07-11-2018 23:40
Hi @GordonFitbit,
The data was synced to Fitbit around 21:00 GMT yesterday. Over 2 hours before I posted the message. The data is still not available in Strava now. It is now 07:38 GMT now the following day.
Thanks for looking into this for me!
07-12-2018 05:57
07-12-2018 05:57
Just did my bike run an hour ago, not showing up in Strava (Ionic with strava app). Worked well for several months.
07-12-2018 11:23
07-12-2018 11:23
Hi @Barry_C...It sounds like you're having problems moving data from Strava to Fitbit. Have you retried syncing your data after 3pm PT?
07-12-2018 15:15
07-12-2018 15:15
What exactly do you mean by syncing after 3:00PM. The sync should be automatic?? Does something special happen at 3:00PM?
07-12-2018 17:43
07-12-2018 17:43
@Barry_C, @Omde Have you tried unlinking the connection from both sides (Fitbit and Strava), then link the accounts again?
07-12-2018 20:19 - edited 07-12-2018 20:20
Hi Robert
i have the opposite issue. Fitbit steps never sync up with MyFitnessPal and Strava. I have tried a lot of times to disconnect and connect again.
Please suggest what I should do
