05-12-2016 02:01
05-12-2016 02:01
Best Answer05-13-2016 02:30
05-13-2016 02:30
Hi @TangoKen
Moved this thread from the Alta to the Third-Party Integrations section since more relevant to the topic & increases the chance of getting a solution.
Best Answer05-19-2016 09:04
05-19-2016 09:04
Hello @TangoKen, welcome aboard to our community. In this case note that your previous activities already logged before the association with your Fitbit account wont be share with strava. But after you have complete this successfully, activities from Strava should be synced over to Fitbit as manually logged activities but will not include GPS or heart rate data from Strava.
Hope this give you some help, otherwise keep me posted.
Best Answer05-21-2016 00:59
05-21-2016 00:59
05-21-2016 01:04
05-21-2016 01:04
Best Answer05-21-2016 08:03
05-21-2016 08:03
Hello @TangoKen, It's ok. No worries my friend. It happens to me all the time, I don't like to read instructions or manuals either. The good news here is that now your activities are syncing. ![]()
See you around and happy stepping.
Best Answer05-22-2016 00:52
05-22-2016 00:52
Best Answer05-22-2016 09:35
05-22-2016 09:35
Best Answer08-05-2016 12:46
08-05-2016 12:46
Hi,
I have a Surge and have followed all of the instructions to link to my strava account but none of the data is going across. I have revoked the access and reset the link up again a number of times and it still wont work.
Can anyone help?
Cheers,
Tom
Best Answer08-05-2016 14:11
08-05-2016 14:11
@TomShannon There was a recent issue with activities syncing over to Strava. Syncing might be slow for a little while as it catches up, but the integration should be working properly again. ![]()
Best Answer08-05-2016 19:47
08-05-2016 19:47
Best Answer08-05-2016 19:50
08-05-2016 19:50
Best Answer08-05-2016 20:21
08-05-2016 20:21
Best Answer08-05-2016 21:16
08-05-2016 21:16
Best Answer08-05-2016 21:42
08-05-2016 21:42
Best Answer08-05-2016 21:47
08-05-2016 21:47
08-05-2016 22:23
08-05-2016 22:23
Best Answer08-06-2016 01:34
08-06-2016 01:34
Best Answer08-06-2016 01:36
08-06-2016 01:36
02:22
10:41
AndrewFitbit
08-06-2016
02:22
10:41
AndrewFitbit
Mines finally come through approx 15hours
Moderator edit: content
