04-08-2019
17:36
07:38
MarcoGFitbit
04-08-2019
17:36
07:38
MarcoGFitbit
Unable to connect snapchat to Fitbit for the Bitmoji watch face, any suggestions?
Moderator Edit: Clarified Subject + Format.
04-09-2019 00:32
04-09-2019 00:32
Also on the same boat please help.
04-09-2019 07:47
04-09-2019 07:47
Hello @TerryBJSR40 and @aprzy thanks for joining the Fitbit Community, it's great to have you on board. 🙂
I appreciate your participation in the Forums and for sharing your experience with us I have moved your post from the iOS board to the Third Party apps board as this situation is more related to the Bitmoji+Snapchat apps than the iOS App itself. At this moment, in case you haven't tried yet, please follow these steps:
If you previously created a Bitmoji account using your email address, but choose to create a new one using the ‘Log in with Snapchat’’ button, your old Bitmoji account will not be available for use within Snapchat. Once you’ve created your new avatar, follow the steps above to connect Bitmoji to Snapchat. Then, you will be able to link Snapchat with Fitbit:
Give these steps a try and let us know the outcome.
04-09-2019 09:22
04-09-2019 09:22
I have done all of those things. After I connect from settings and login to my snapchat account is when it does nothing. I get a blank white screen
04-09-2019 09:51
04-09-2019 09:51
same! and my fit bit app just closes out, so i can't even go in and return to a previous clock face...so frustrating.
04-09-2019 10:05
04-09-2019 10:05
04-09-2019 10:14
04-09-2019 10:14
just did this again and still nothing. It is showing that my app is linked. Now i just get a blue screen on my fit bit with what i call the spinning wheel of death
04-09-2019 10:25
04-09-2019 10:25
I did all of this and now i am just getting a blue screen on my fitbit face with the spinning wheel of death and my fitbit app still closes out on my phone
04-10-2019 08:01
04-10-2019 08:01
04-16-2019 07:01
04-16-2019 07:01
I downloaded the bitmoji clockface, I clicked the settings in Clock faces and then click to connect snapchat but when it brings me to the snapchat login screen it just keeps making me log in and does nothing. I know my username and password are correct because I checked in my snapchat app....what am i doing wrong??
04-16-2019 10:51
04-16-2019 10:51
Hello everyone!
I apologize for the delay in my response. Thanks for taking the time to try the steps we have recommended.
@SFREA113, Did you get a chance to try the steps that have been mentioned above? They should definitely work.
For the rest, I'd like to ask if the situation has continued or if it has been resolved and working correctly since then?
I look forward to your replies.
04-16-2019 10:56
04-16-2019 10:56
I have not tried anything again because it was such a nightmare the first time. It's not worth it to me and now my fitbit doesn't seem to vibrating when texts come in like it used to. I wont try it again because i don't to mess more stuff up.
04-16-2019 11:14
04-16-2019 11:14
I have done the steps above up to connecting to shapchat. When i hit connect, it brings me to the snapchat login screen but then when i log in it goes back to the snapchat log in screen...nothing happens.
04-16-2019 11:31
04-16-2019 11:31
Hello @SFREA113 and @FitJennR.
Thank you for your quick replies!
@FitJennR In this case I'd like to ask you to confirm that you are using the latest version of the Fitbit app and the firmware on your Fitbit. You can click here to read more about updating the Fitbit's firmware.
As for the latest version of the app you can click here to read about the latest iOS version, Android version and Windows 10 version.
As for the notifications please try troubleshooting them as it says in this help article.
@SFREA113 Thanks for bringing this up. Please know that our team is working on getting the link to connect the two updated to the correct one. You should be able to get the accounts connected by clicking here. and following the steps in there.
Hope this helps! Be sure to let me know if there are any other questions.
04-16-2019 11:38
04-16-2019 11:38
04-16-2019 11:50
04-16-2019 11:50
Hello @SFREA113.
Thanks for your quick reply.
In that case I'd like to recommend that you try getting in touch with Snapchat directly since this is happening once you are on their log in page. They should be able to look into what is going on and help you make sure that you are able to log in.
Feel free to reach out if you have any further questions.
04-16-2019 11:54
04-16-2019 11:54
04-16-2019 12:11
04-16-2019 12:11
04-16-2019 12:13
04-16-2019 12:13
Where in snapchat do you connect it?
04-17-2019 19:45
04-17-2019 19:45
I did all these steps, and it says that it's "Teleporting to smartwatch" but it stays at 0%. They suggested I swipe up and down again to restart the clock face, but that doesn't work either. I'm so close...
