12-26-2015 08:37
12-26-2015 08:37
Has anyone integrated to a Weight Gurus scale?
12-31-2015 09:13
12-31-2015 09:13
12-30-2015 11:12
12-30-2015 11:12
I just did this yesterday but for some reason only the weight recording is showing (not body fat %). I have a message into the Greater Good folks to see why this is. Hopefully it's a quick fix.
12-31-2015 08:42
12-31-2015 08:42
What did you have to do to get the weight from the scale to integrate to FitBit?
Thanks.
 Best Answer12-31-2015 09:13
12-31-2015 09:13
12-31-2015 09:45
12-31-2015 09:45
Wow. I was looking on the desktop version of WeightGurus and it was not there - but it is on the app on the iphone.
Thanks for the help!
02-02-2016 15:19
02-02-2016 15:19
Thanks for this information. I was looking in the wrong place for the FitBit integration. Works great now!
02-04-2016 11:58
02-04-2016 11:58
02-07-2016 19:33
02-07-2016 19:33
 Best Answer02-08-2016 06:09
02-08-2016 06:09
 Best Answer03-26-2016 12:16
03-26-2016 12:16
 Best Answer05-16-2016 14:37
05-16-2016 14:37
I did this and it says it is integrated, but I do not see any data fromt he scales being loaded into the FitBit app.
Did I miss something?
Am I expecting too much?
05-16-2016 15:26
05-16-2016 15:26
Mine will occasionally lose it's mind for some reason. I've had to go back in and re-enable the integration and everything works out fine from then on. It will back-load the data that was missed once it gets everything under control again. I would say it has happened maybe 3 times in the last 4-5 months.
05-17-2016 18:29
05-17-2016 18:29
 Best Answer05-18-2016 07:36
05-18-2016 07:36
Has anyone figure out how to fix this problem. I have logout and and disable the intergration and re-enable but it's still not syncing my data. Thanks
05-19-2016 09:02
05-19-2016 09:02
Bump.
Anyone else shed some light on this? In the Weight Guru's app, under Integration, I have Fitibit turned "on", logged in, etc. The measurements logged in the WG app still isn't showing up in Fitbit...
06-03-2016 15:39
06-03-2016 15:39
So the scale doesn't really sync with the fitbit, but instead with your mobile device which in turn logs it on fitbit account?
My wife and I both have fitbits, does this mean we have to push a button on scale to get it to log to our correct fitbit accounts?  How does the scale know which fitbit account to log the data?
 Best Answer06-03-2016 19:02
06-03-2016 19:02
08-05-2016 15:20
08-05-2016 15:20
After setting up the integration in the Weight Gurus app, try closing the fitbit app and re-opening it. That did the trick for me.
09-19-2016 07:59
09-19-2016 07:59
I've had a FITBIT CHARGE for a couple yrs now -- just got the WEIGHT GURUS Signature Series WiFi Smart Scale last night. This morning - 1st weigh in - so not much data to view -- I turned on FITBIT integration this morning as well - but NOW WHAT? I've searched all over trying to find out WHAT EXACTLY this integration does and>>
(1) will be be auto-synched (I have auto-sync turned on between the phone and the scale) - or must I do something to PUSH the FITBIT data into the WG app that's tracking things like Muscle Mass, Water Level, etc.?
(2) I was super excited to have a ton of metrics to view on the WG app- but seems so basic...watched a Youtube video of the app of 2014 and it looks way more elaborate and colorful than this one does in 2016..maybe they just stripped it down to bare bones recently for non-technie users...?
(3) Will additional info feed to the WG phone app or laptop app such as steps or level of activity if I've been on the treadmill? I guess I'm confused because my FITBIT tracks steps, miles walked/ran, heartrate, level of intensity etc and there seems to be nowhere within the WG phone or laptop app that is displaying additional metrics collected by the Fitbit??
(4) I love how on the Fitbit app you can see Daily detail etc, but on the WG app it only seems to show by Week, Mo, Yr or All? Am I missing something? I'd like to go one place and see my WATER level (because the scale provides this), or see if muscle mass increased that day after lifting weights for a couple hours... but appears the minimum is a result by Week!?
Hope you guys that have been using these 2 together in an "intergrated" fashion can enlighten me!
Thanks greatly! Chris
03-10-2017 18:23
03-10-2017 18:23
Have you heard back from them? Mine is doing the same thing.
Thanks in advance!
