10-20-2020
00:42
20:52
10-20-2020
00:42
20:52
How do I set location for weather app?.
Hi there @Ridb, it's nice to see you around the Community Forums. I'll be glad to help you with your inquiry about setting the location for Weather app on your Versa 3.
As @JohnnyRow mentioned, to set up the Weather app:
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
Let me know how it goes.
Hey @Ridb, you're very welcome! I'm glad to hear you were able to set the locate for the Weather app on your Versa 3. 😉
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Have a nice day!
Best AnswerI have followed the directions and I cannot get my weather to work. When I try to add a city, it just spins and spins and never adds the city. If I use "current location", it gives me a city about 25-30 miles away from me. I have been trying to get this work on and off for over a year now and it has never worked.
10:13
07:57
02-02-2022
10:13
07:57
HI @Grissa - there is probably a bug so that it only really works with current location, adding cities may stop it working. If this is the wrong location certain setups may not be correct.
How it derives current location is uncertain as to the exact source it uses but you could try to make sure your phone locations [and improved accuracy setting] and Fitbit App are setup with all the required permissions and automatic time zone is enabled in the Fitbit App.
Then restart both watch and phone and ensure they are syncing properly.
It may help.
The only place I can find any list of apps is under "gallery," which is listed in the icons when I tap versa3 on my profile. All the permissions are enabled and location is set to current location. The Fitbit app on my phone is allowed "all the time" for location under my settings. I've restarted the Fitbit and my phone.
When I tap weather on my Fitbit device the message comes up. No location information. Go to the Fitbit mobile app to set up weather.
I'm about 45 minutes into this not working, researching online and trying everything.
Please help!
Hi @Mabowen - see all the instructions in this post, it may help. How to change Temperature - for Weather, Centigrade - Fahrenheit, Versa 3
