04-13-2021 08:55 - last edited on 12-18-2022 20:47 by MatthewFitbit
My Versa 3 is going crazy with counting stairs. I haven’t even walked 600 steps today and it is telling me I’ve climbed 13 flights of stairs. I live in a ranch style home with no steps. I’m so confused. How do I fix this?
07-06-2021 13:40
07-06-2021 13:40
So you are saying when the November Software was updated, that it broke every bodies hardware?
07-08-2021 06:49
07-08-2021 06:49
The problem has been for more than 6 months!!! Why Fitbit doesn't take this issue seriously and sort it out once and for all, it gets really frustrating!!!!
07-09-2021 00:22
07-09-2021 00:22
@Rich_Laue Yes the firmware update from the initial 44.128.1.42 to 44.128.4.17 broke the floor counting,
The update to 44.128.5.38 didn't fix it.
Just recently, with neither a Fitbit App update or a firmware update its got worse, which suggests an issue elsewhere.
While it will count correctly if you go up a flight of stairs, so the watch is working properly, there is some other interference that has been introduced in an algorithm somewhere which counts spurious floors randomly.
The Versa 1 counts fine and is still the watch of reference.
As regards it affecting some watches - this is most likely an incorrect assumption. It is more likely that most people don't monitor floors or don't report it. The problem affects the Sense quoted here in the same way.
07-11-2021 10:14
07-11-2021 10:14
Days go by and still no update to fix this problem ....
01-05-2022 07:36
01-05-2022 07:36
My Versa 3 was working fine. I knew flight counts were not close to 100% but it was close. Yesterday, it told me I did 75 flights of stairs. It was my like 8-10. I chatted to someone yesterday. I had read all the comments above. This is a long known issue. My FitBit representative at first acted surprised. “Really? Did it get wet?” Then a description of how it counts flights. He said he submitted it as a bug. I responded about others experiencing the problem. He finally admitted they know about it. No solution. “We are working hard.”
01-07-2022 06:01
01-07-2022 06:01
I've had this problem since the first day. I had my Versa 3 substituted but with the same problem. The customer service can only say they're working to fix it but that's not true, after 14 months i daresay versa 3 and sense have been built bad.
01-07-2022 08:12
01-07-2022 08:12
I’m guessing it is a hardware fix. If they could do it with firmware they would. Hardware means replacement. That is costly.
01-07-2022 08:19
01-07-2022 08:19
Problem is they just keep making new models and basically hoping no one stops buying flawed hardware... sucks because again. The Charge 2 was perfect, if not a bit fragile...
01-07-2022 08:28
01-07-2022 08:36
01-07-2022 08:36
Correct actually. As there were many reports of it breaking after a certain firmware update. They should have just let us revert...
01-18-2022 07:48
01-18-2022 07:48
Hi everyone, thank you for taking the time to share all this information and updates about the problem you've been experiencing with your Versa 3.
If you haven't done so already or if you're new to this thread, make sure that you've completed the restart procedure, as this has been useful for some users experiencing similar problems. In addition, please review the information in this article about why the watch may be tracking extra floors.
At the same time, and as mentioned earlier, keep in mind the team is already aware of this problem and they continue to work to find a solution as soon as possible, but we haven't received other updates for the moment.
If you already tried all the recommendations in the forums, you can also get in touch with the Customer Support team for further assistance with this. Click here to get connected.
Have a good day.
01-21-2022 04:35
01-21-2022 04:35
Hi @Tupps - If you are interested in verifying how your watch pressure sensor is behaving or whether you can get a more accurate floor count, try the SimpleFloors app.
It shows how your watch is affected by environmental issues, such as going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc. and has it's own algorithm which seems more realistic
Don't use it for too long as it is always on and uses quite a lot of battery.
01-27-2022 05:48
01-27-2022 06:44
01-27-2022 06:44
My device has issues with counting floors climbed …..oddly it doesn’t count them at all at times ……frustrating .
My device has already been replaced by Fitbit once for miscounting heart rate , basically the thing doesn’t do what Fitbit advertise it as being able to do .
02-21-2022 17:45
02-21-2022 17:45
I just got the Versa 3 at the end of January, and mine is doing this as well. I probably went up our basement stairs about 7-8 times and my versa 3 says 31 times. It is VERY frustrating!!
02-22-2022 01:33
02-22-2022 01:33
Hey , I have no idea how to fix the issue ….I deleted the stair count from my dashboard because of it .
Apparently I climbed 100 flights of stairs a few days ago 😂😂😂
Basically the Fitbit doesn’t do what the developers claim ….I might change brands and get something that works .
02-23-2022 08:15
02-23-2022 08:15
I do think it telling that no Fitbit moderator has commented on this thread …….that says so much .
03-01-2022 10:54
03-01-2022 10:54
Hi, thank you for all your replies about this inconvenience with your Versa 3, @shayemimi @RatDog1.
I'm sorry to see that you're still having this issue with the watch. In this case, since you already tried all the recommendations mentioned here earlier, I recommend that you continue the communication with the Customer Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected
I appreciate all the feedback and comments that you've provided about the product so far.
See you around.
03-01-2022 23:47
03-01-2022 23:47
I’ve had several conversations with Fitbit support and none of the recommended procedures have made any difference .
03-02-2022 02:58 - edited 03-02-2022 03:01
Please see the best answee
realizing that the pressure change of 1 floor is equivalent to the weight of a 1X2 inch piece of paper.
What may help is cleaning the hole or shutting down and starting the tracker.
The very small change needed can be easily mimicked by a slight gust of air blowing over the arm. Some have found that walking past a fan can add a floor
