10-24-2022
		21:14
		13:59
			ManuFitbit
		10-24-2022
		21:14
		13:59
			ManuFitbit
My device no longer locks when taking it off my wrist. My fear is if my Fitbit gets lost someone can take it and do a factory reset. My Versa 2 locked with no problem. I feel like there is minimal protection with this watch. If there is a fix please let me know.
Moderator edit: clarified subject.
 Best Answer10-25-2022 06:01
10-25-2022 06:01
I've had this issue from day 1 of getting my versa 4. It won't device lock it automatically sets it to fitbit pay lock and I haven't even set up a card to do so.
I've contacted fit bit over a week ago and still they can't help me. Just keep saying we need more time to figure it out.
Pretty lame excuse.
10-24-2022 21:51
                              10-24-2022 21:51
It's up to you to set the device lock.
Read about it and how to set it here:
How do I use the device lock on my Fitbit device?
10-25-2022 06:01
10-25-2022 06:01
Pretty lame excuse.
		10-25-2022
		06:05
		13:55
			ManuFitbit
		10-25-2022
		06:05
		13:55
			ManuFitbit
Thank you for paying attention to what I said. Someone sent the same exact article. The device lock only works for Fitbit pay on Versa 4 and that’s not what I’m talking about! I need it to lock every time my watch leave my wrist for security reasons 😪
i don’t think you understood my issue. I know how to set device lock. On Versa 4 it only works for Fitbit pay which means if I happen to leave my watch somewhere accidentally anyone can go into it and reset it to factory settings and boom now it’s no longer my watch. My old versa 2 locked automatically every time the device came off my wrist. This saved me from having my watch stolen.
fitbit needs to fix this asap as they are putting our devices at risk. I don’t have 300 to throw away. 🤔
10-25-2022 06:14
10-25-2022 06:14
Is this happening on all versa 4 watches? This is such a key feature.
I've just spoken to fitbit again and they say it could be a feature they are going to release. In my opinion it should be standard.
10-28-2022 16:26
10-28-2022 16:26
I'm having the same problem, I don't have 300 to through away either.
11-11-2022 05:30
11-11-2022 05:30
Still got thus issue. Never heard back from fitbit....poor customer service 👎🏻
11-17-2022 16:44
11-17-2022 16:44
I agree 110%. It is unbelievable that Fitbit would release a smartwatch without this required feature. A fix/patch should have been issued weeks ago.
12-02-2022 01:22
12-02-2022 01:22
Anyone had any luck with this issue yet?
12-20-2022 07:04
12-20-2022 07:04
Anyone with luck?
 Best Answer12-20-2022 07:59
12-20-2022 07:59
Looks like device lock prevents only from accessing Fitbit/Google Pay rather than whole device. It's like that on Sense 2. Basically, there is no system-wide device lock on those devices.
 Best Answer03-29-2023 05:22
03-29-2023 05:22
I wish I would have discovered this thread before I bought the versa 4. I definitely would not have purchased it.
03-29-2023 05:48
03-29-2023 05:48
I returned my Versa 4 back to Argos earlier today, this watch is not ready for release. It has a lot of missing logic, and the logic that is there is definitley suspect on accuracy
03-29-2023 14:34
                              03-29-2023 14:34
@t.parker when setting up the device lock, it defaults to locking the whole device.
At this time, we have the choice to choose Lock Fitbit Pay only. Once this option has been chosen, you can't unchoise it without remiveing cards, disabling the lock and then setting things up
@Talesha386 having a pin lock will not stop someone from doing a factory reset. There is a hardware based reset option availible.
 Best Answer06-20-2023 17:43
06-20-2023 17:43
I just got my Versa 4 today and also extremely shocked to find out the screen doesn’t lock like my Versa 2 did. Unless Fitbit can come up with a fix for this I may also return mine!
06-21-2023 17:44
                              06-21-2023 17:44
Hi @Sulli100 are you referring to needing a pin code? Have you setup fitbit or Google pay?
In the fitbit app - tap the profile picture - tap the Versa 4 - Tap device lock ( the last item)
Is it set for Wallet Only?
