11-29-2022
20:23
15:43
11-29-2022
20:23
15:43
My versa 4 is not syncing with my text messages. I am getting other calls and notifications, but even though I have it set to show texts, they are not showing up. How do I change this?
Hi there, @Jenny1216. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
While reading your post I was wondering (in case you're an iOS user) if the text messages your Versa 3 is not receiving are iMessages? I also have an iPhone and had a similar trouble with those messages, but I tried toggling the iMessage setting; general > Messages > iMessage and verified the "Show Previews" was on "Always". If this steps don't work for you, I suggest taking a look at the help article: Troubleshooting quick tips for iPhones.
12-02-2022
02:41
12:50
AndreaFitbit
12-02-2022
02:41
12:50
AndreaFitbit
Hi, I'm having the same issue on versa 4, I have a Samsung 21. I get phone call notification but not messages, normal or what's app. I have turned on notifications etc, all help appreciated
Thanks
Andy
Moderator edit: format.
Hi there, @Andy45_M. Welcome on board! Thanks for trying to solve the issue with your Versa 4 before posting here.
In addition to the steps you've done so far, please see Why are notifications delayed or missing?
See you around.
This is happening to me also…I have done everything literally everything to fix this issue. I’m not sure who to contact next. Any help would be appreciated. Thank you 😊 I’m really regretting upgrading to the 4 now and I’ve only had it a month 🤦:female_sign:
I have too, and the article about troubleshooting doesn’t actually troubleshoot anything. The article just says check a setting. I’ve checked every single notification setting for messages and nothing has worked.
I also upgraded to a Versa 4 and cannot get messages or WhatsApp on it.
I’ve tried everything to fix it.
super annoying.
Mine started working!!!! …
I was told to go to settings -> message -> notifications -> turn Show Preview to Always.
I did that then started getting full message on my Lock Screen (because that what I set it to) and didn’t like it, so I changed it to Show Preview on When Unlocked INSTEAD OF Always. And whammy, I started getting them on my watch. Not sure if you can just start directly with Show when Unlocked and it will work, but specifically turning it to Always, wait until you get a couple texts that show on your Lock Screen, then go back in and change it to Show when Unlocked.
hopefully it works for you too!!!
I’ve tried your fix but sadly still no luck here?
are you using an iPhone? I have an iPhone 11 pro
I have an iPhone 12. Oh, another thing i did. In your Send and Recieve section, in your Message setting again, make sure the @iCloud address is checked and active. I also clicked on and off the iMessage box a couple times, right above that Send and Recieve setting, ultimately leaving it on. That last part probably didn’t do anything but maybe.
Progress!!!!
im now getting imessages coming through on my versa 4 but still no joy with the WhatsApp messages. 🤣
12-13-2022
15:53
03:21
12-13-2022
15:53
03:21
Hi there, @JoBell34, @Kschlab and @Juliemross.
@JoBell34 Thanks for trying the steps shared in this thread. Just to confirm, did you make sure the Show Preview are set as Always or When Unlocked? If that's correct, let's try reconnecting your watch to the Fitbit app by doing the following:
@Kschlab and @Juliemross Thanks for keeping me posted and your efforts while working on this matter. I'm glad you sorted this out and I'm sure your posts will help other members around the forums.
Hi there, @JoBell34.
Thanks for confirming that you've tried the suggestions shared in this thread. I appreciate your efforts and I'm sorry the issue is still persisting. Given this situation, I've requested a case on your behalf so you can receive further assistance from our Support team. They'll get in touch with you via email, please keep an eye on your inbox.
@JoBell34 It's good to see you again.
You're very welcome. Your case is in good hands and I'm sure they'll continue helping you, so please keep an open communication with them. Happy holidays!
