09-09-2024
03:08
09:44
LizzyFitbit
09-09-2024
03:08
09:44
LizzyFitbit
I've just recently noticed an issue where the time on my watch should've been 12:15pm was at 9:15am instead. The App settings for timezone information was set automatically. I then manually set it to the correct timezone but the time doesn't change even after syncing. If I sync a timezone just before mine (GMT+2) it then works and sync to one hour behind. If I change it back to GMT+3 it then goes back to the original time which is a couple hours behind the correct time. This leads me to believe that there's some bug, I've also restarted my phone and watch but to no avail, entering specifically GMT+3 it doesn't work. I haven't test it with GMT+4 to see what happens but this behaviour is very weird since it gets the other timezones correct, at least those before my current time.
Is anyone able to replicate this?
09-09-2024 09:46 - edited 09-09-2024 09:58
Hi everyone, and welcome to our new members. @Talahthas Thanks for your help!
Thanks for bringing this to our attention and the time taken while troubleshooting your watches. I wanted to let you know that this issue was escalated and our team got it fixed.
I appreciate your patience and if you continue seeing the wrong time, I'd suggest opening the Fitbit app and pulling down on the Today screen to force a sync.
09-09-2024 03:31
09-09-2024 03:31
The strange thing is my laptop which is using linux and with ntp enabled, it also picks up the exact same incorrect time...
Best Answer09-09-2024 03:34
09-09-2024 03:34
Welcome to the Fitbit community, @talhahp!
All in all this seems to be a problem with your internet access in general.
Have you tried restarting your router? Are you using VPN for your internet connection?
Best Answer09-09-2024 03:49
09-09-2024 03:49
My internet access is fine and I'm not using a VPN. I think some NTP server somewhere is giving incorrect timezones because my watch, laptop and desktop all had the wrong time despite not being connected to the other. I'll give it some time to fix itself and see.
03:49
04:50
09-09-2024
03:49
04:50
My timezone is incorrect after updating yesterday night
09-09-2024 04:16
09-09-2024 04:16
This is a strange coincidence, my laptop and desktop time were incorrect due to a broken update with a package tzdata. More info here: https://www.reddit.com/r/archlinux/comments/1fc5o2f/waybar_suddenly_has_the_wrong_time/
I'm not sure how it relates to fitbit but just pointing it out.
Best Answer09-09-2024 04:57
09-09-2024 04:57
After doing further research, it seems multiple projects have been affected by this bug and it's plausible fitbit is too. Hopefully this can be fixed in due time as it's really annoying.
https://gitlab.archlinux.org/archlinux/packaging/packages/tzdata/-/issues/1
09-09-2024 05:02
09-09-2024 05:02
Have tried restarting, pairing and unpairing even factory resetting, the versa 4 clock is stuck on 8 hours before my actual time zone(gmt+8) after syncing.
09-09-2024 05:05
09-09-2024 05:05
My Versa 4 is not updated with my time zone. Today in the morning was ok, but after some hours, about 2 hours ago, the time in my Versa4 changed for 3 hours after my time zone. Anyone knows what happened?
09-09-2024 05:19
09-09-2024 05:19
mine too tried everything still to no avail
09-09-2024 05:22
09-09-2024 05:22
Hi. My watch change the time automatically, I sew in the Fitbit app, and check my locación, is correct , I sync the watch , but Still is the same. I set the location to a city in a different time zone - Sync, change the time, but when I set tot to the correct location and Sync again., doesn't work!!!
One of the two should fix your time.
Best Answer09-09-2024 05:32
09-09-2024 05:32
Don't know how but the time on my watch changed. I did everything from switching on and off the app as well as the watch. Changed the time zone on the app and synced it. Turned the bluetooth on and off and then synced again. Uninstalled and reinstalled the app yet can't get the correct time on my watch.
09-09-2024 05:41
09-09-2024 05:41
People that have Sense 2 devices are having the same issue. Ure not alone!
09-09-2024 05:41
09-09-2024 05:41
Hi. My watch change the time automatically, I sew in the Fitbit app, and check my locación, is correct , I sync the watch , but Still is the same. I set the location to a city in a different time zone - Sync, change the time, but when I set tot to the correct location and Sync again., doesn't work!!! it is showing GMT+0 .
Best Answer09-09-2024 05:43
09-09-2024 05:43
Mine too could it be the apps problem? I have been trying all methods but the watch stuck 8hrs back
Best Answer09-09-2024 05:44
09-09-2024 05:44
I have the same issue. It’s four hours ahead of my time zone and none of the troubleshooting seems to work. This is so frustrating!
09-09-2024 05:45
09-09-2024 05:45
should be due to new tracker software update..
Best Answer09-09-2024 05:46
09-09-2024 05:46
you can set it to Australia Perth time zone. i tried Shanghai.. it became mandarin... Kuala Lumpur doesnt work, affected same as Singapore
09-09-2024 05:46
09-09-2024 05:46
I have the same issue. And I see that many people having the same issue. None of the troubleshooting seems to work. Sigh
09-09-2024 05:46
My versa 4 have the same problem and its stuck 8hrs behind my timezone. Is this a worldwide problem? Any chance to solve the problem?
