09-06-2024 11:56
09-06-2024 11:56
We’re excited to announce that a firmware update version 210.26 for Versa 4 has been released to all our members. Some of you might already have this update available. If you installed it, let us know what you think!
We release updates to customers in phases. If you don’t see it, check the Fitbit app in a few days, and you’ll see a message when you can install the update. We appreciate your patience while we get this update to all of our customers.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
Full release notes can be found here.
HOW DO I UPDATE?
See How do I update my Fitbit device? for step by step instructions for updating your Versa 4. If you run into difficulty updating, review these Why can't I update my Fitbit device?
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
09-29-2024 00:24
09-29-2024 00:24
I am trying to update my Versa 4 firmware from version 61.20001.184.52, but there is no pink update button. How do I update it then?
09-29-2024 06:47
09-29-2024 06:47
This entire thread has had so many problems with the new update it’s rendered our fitbits almost useless. If i were you I’d read the problems and possibly try to prevent it.
09-29-2024 07:33
09-29-2024 07:33
I just read that Fitbit is phasing out by the end of September and it will just be Google. Here is the article that popped up on my feed.
09-29-2024 21:59
09-29-2024 21:59
09-30-2024 06:24
09-30-2024 06:24
This is amazing! Thank you for sharing. At least I know now I’ll have to move to something else.
09-30-2024 09:52
09-30-2024 09:52
You know I'm beginning to think the same thing. I will be contacting Google later today to see if any of this can be resolved. This is just so unbelievably. There have been so many complaints about this and I have been with Fitbit for years, you would think that we shouldn't have to contact them they should be reaching out to us.
10-01-2024 12:04
10-01-2024 12:04
10-01-2024 14:05
10-01-2024 14:05
If you can't update it yourself contact Google so they can take you through the process of updating it.
10-02-2024
20:49
08:59
FatimaFitbit
10-02-2024
20:49
08:59
FatimaFitbit
This update has essentially made my Versa 4 unusable. It starts an exercise while I am not doing anything, chooses to set screen to always on, and trying to fix it does not make a difference. I try to change display settings, and nothing happens, This is not an update , it's a hot mess. Fix this ASAP.
Moderator Edit: Word choice
10-03-2024 07:06
10-03-2024 07:06
My watch/tracker no longer works since this update. It turns on and I get the Fitbit logo diamond then it inverts and then it goes back to normal. It does this a few times then I get a red X. This is unacceptable because it was working great before the update and not it does work at all. I've done everything I can as far as what I've read and nothing seems to fix it. My phone wants to sync with it BUT the code never shows up on the screen.
10-04-2024 06:04
10-04-2024 06:04
Ever since the update I have had issues with my heart rate showing higher than it really is. I have manually confirmed my heart rate and my Fitbit is reading higher than it should. I also am showing many more floors and I should have
10-05-2024 21:35
10-05-2024 21:35
Totally agree. The fitbit and the app used to be great. The prior version of the app looked better and was easier to use. The new app sucks and it doesnt show pace and it doesnt track consistently. It’s painful to use. This is my 6th and last fitbit. It’s crap now.
10-08-2024 11:40
10-08-2024 11:40
I think that Fitbit users need to know what is actually going on. I hate to see my Fitbit family going through this. Can someone from Google please let us all know what's going on? I don't want my Fitbit family to continue leaving or giving up on this. I appreciate them very much, they have showed me so much support that I greatly needed and I hope that they will be able to continue doing so. We are a family, someone help fix these issues so many of us are having.
10-10-2024 07:44
10-10-2024 07:44
10-12-2024 21:02
10-12-2024 21:02
Seems to be problems in Fitbitworld. It has taken me almost fifteen minutes just to find this thread. I came to say that I bought a different tracker, so I won't be fighting this website any more. It was fun and helpful for a number of years, but this looks like the end of the road. I wish you all well.
10-13-2024 05:04
10-13-2024 05:04
10-13-2024 11:10
10-13-2024 11:10
10-13-2024 15:13
10-13-2024 15:13
thanks for the post. i suspected that fitbit was going to disappear.
10-13-2024 16:12
10-13-2024 16:12
10-14-2024 10:57
10-14-2024 10:57
UGH!!! HOW DO I UNDO THIS UPDATE?!? This update made my watch stop sinking with my phone!!! It won't let Bluetooth connect all of a sudden for NOTHING!! I've tried rebooting the app, refreshing the app, erasing the app and re-downloading it, I've tried turning Bluetooth on and off about a million times!! How do I get rid of this new update?!? PLEASE HELP!!!
