12-04-2023
15:19
16:56
AndreaFitbit
12-04-2023
15:19
16:56
AndreaFitbit
Why is my versa 4 battery life suddenly shorter than normal
Moderator Edit: Clarified subject.
Best Answer12-06-2023 03:09
12-06-2023 03:09
I have fixed the short battery life on my versa 4 by turning off the gps feature
12-04-2023 15:35
12-04-2023 15:35
@bluey52 Is it possible you have the always-on display turned on? Swipe down from the clock face and make sure the icon on the bottom left that looks like a clock is not illuminated.
12-04-2023 15:39
12-04-2023 15:39
Best Answer12-04-2023 15:45
12-04-2023 15:45
@bluey52 Are you using an SpO2 clock face?
If nothing else has changed then I would restart the watch to see if that fixes the issue.
Best Answer12-04-2023 16:24
12-04-2023 16:24
Best Answer12-04-2023 16:25
12-04-2023 16:25
what is a spo2 clock face ?
12-06-2023 03:09
12-06-2023 04:57
12-06-2023 04:57
I have had 4 of these. This current on is a replacement because the previous ones batter wouldn’t last 24 hours. I contacted customer support and they had me try an few things and then ultimately the sent me a replacement.
Best Answer12-06-2023 16:55 - edited 12-06-2023 17:01
Appreciate your recommendation. Will see what happens. I use the Fenix 7 as my go to and absolutely no issues …of course a bit pricy.
Best Answer12-08-2023 05:03
12-08-2023 05:03
Fitbit SpO2 displays your SpO2 percentage detected during sleep as an average. Certain clock faces available on Inspire 3, Sense series, and Versa series can also show your SpO2 range. The Fitbit SpO2 values can range from 80% - 100%. Fitbit SpO2 does not measure or display SpO2 values lower than 80%.
