11-30-2023 09:16
11-30-2023 09:16
After only 10 days, my screen quick working and won't respond to touch. When I press the button all it does is vibrate. No change when I try to charge it; the screen stays black but it vibrates when the charger is connected.
Fitbit was on 21% when it quit working. I have no idea if it's actually charging because it will not sync with the app. I let it "charge" for a couple hours so I could try resetting it, but doesn't do anything. Absolute trash!
11-30-2023 20:21
11-30-2023 20:21
Hi @LisaR67 - it sounds like it is not charging, see How to check charge cable - Sense 2/Versa 4 won't charge, won't start or blank screen
Best Answer11-30-2023 20:34
11-30-2023 20:34
The screen went black before I even tried charging it. And, yes, I cleaned the contacts and nothing changed. Usually when I plug it in to charge it vibrates and then shows the charging status. The screen remains blank. And it won't sync to my app anymore. The battery was not dead when it quit working.
Best Answer11-30-2023 21:28
11-30-2023 22:15
11-30-2023 22:15
Best Answer11-30-2023 22:33
12-01-2023 07:03
12-01-2023 07:03
Best Answer12-03-2023 12:42
12-03-2023 12:42
I am having the issue with my 1 week old fitbit versa LisaR67. Have you gotten any assistance from Fitbit?
Best Answer12-03-2023 13:01
12-03-2023 13:01
Best Answer12-03-2023 13:19
12-03-2023 13:19
Best Answer12-03-2023 13:45
12-03-2023 13:45
Best Answer12-03-2023 14:11
12-03-2023 14:11
12-03-2023 16:20
12-03-2023 16:20
Just received my versa 4 and it’s not working correctly. Each time I check the time the Fitbit logo appears for about 20sec then the watch face works. Had a :cross_mark: on the screen. Tried to reset it but hasn’t helped. I’ve had a Fitbit for 10+ years. Jane been happy up until now. I’ve contacted Fitbit help. Will let you know how I go. NOT HAPPY
Best Answer12-04-2023 14:04
12-04-2023 14:04
I am not happy, any more!! They made the replacement process really easy... however they never said they would be replacing it with a REFURBISHED Fitbit. I paid for a new Fitbit, I expect a NEW replacement!!
Best Answer12-04-2023 14:44
12-04-2023 14:44
Ok. Talked to Support again, about the 'Refurbished' replacement. I was told the only 'refurbishment' was that they updated its firmware before being sent. Hopefully this is a good thing and the same problem doesn't persist. We'll see.
Best Answer12-04-2023 17:24
12-04-2023 17:24
Best Answer12-04-2023 18:40
12-04-2023 18:43
12-04-2023 18:43
Tried that but doesn't work because it won't sync.
Best Answer12-04-2023 18:46
12-04-2023 18:51
