09-09-2024
14:26
14:41
09-09-2024
14:26
14:41
When I put my Versa 4 on the charger, the screen keeps switching from the home screen to the charging screen every 5 seconds and isn't actually charging.
I'm using the charger it came with, and the pins are all aligned etc.
Any ideas? I only bought it 3 days ago!
Thank you
Hi there, @ShellF84. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 4 is still not charging despite you using the original charger. I understand your concern, I will do my best to help you with this!
As per the description of your post, it could be a sign the contacts need cleaning. Dust and debris can accumulate over time. Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
Please find below some tips to best charge Fitbit devices:
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
