Aukey T10 + Versa 2
I bought some Aukey T10 True Wireless earbuds. They are comfortable and sound great, and most importantly, stay in during worries. Sadly they work with everything but my Versa 2.
I see the headset in the Bluetooth settings, I get the green check mark saying it had paired, and I can play music. 5 minutes later the earbuds disconnect as though they never paired (even though they were playing music from the Versa 2). They also won't auto connect after pairing (again, only with the Versa 2).
I've tried wiping the connections list on the earbuds, restarting the watch, shut down and reboot on the watch, factory reset the watch, and removed and re-added the earbuds countless times.
Had anyone else had similar issues with this device or others, or perhaps had any luck with the Aukey T10 (that would at least give me some how)?
3 REPLIES 3
Sadly, I have now attempted to use the Aukey T10 on a second Versa 2 with the same results. Also of note is that the Versa 2 is unable to adjust the volume with these. The headset has worked flawlessly with 3 other devices, and 2 other headsets have worked fine with the Versa 2. Unfortunately, if this Bluetooth communication isn't worked out between the two I may just have to return both devices, since the whole point of the earbuds was to work with the watch, and I choose the Versa 2 to use with on-board music. [shrug]
I'm having this same exact issue with the Samsung Gear Icon X wireless buds. I literally bought the Versa 2 for the onboard storage option. This is so frustrating. What earbuds worked for you?
I responded to a different thread (below) with a list of the headphones I tried and whether or not they worked. In short, I'm using the Jaybird Vista's, but you can see what other people have had success with there:
https://community.fitbit.com/t5/Versa-Smartwatches/What-Headphones-Work-With-Versa/m-p/3984384/highl...
