08-06-2018
13:45
07:27
MarcoGFitbit
08-06-2018
13:45
07:27
MarcoGFitbit
Please fix the sleep tracking on my new fitbit versa. I love the watch but miss not having any kind of accurate sleep tracking. Very disappointed and would not recommend this product until the issue is resolved.
08-07-2018 07:31
08-07-2018 07:31
Hello @rceskavich, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
Thanks for bringing this to my attention. Tell me, have you restarted your Versa lately by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen?
Please note that the Fitbit app currently has in-app error notifications that provide an explanation for why you aren't receiving Sleep Stages on any given night. This is meant to provide insight into what might be occurring to cause this.The error messages are the following:
When you tap on Learn more, you will be able to get more information about why your tracker didn't record sleep stages. Additionally, I'd like to suggest the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
08-20-2018 08:31
08-20-2018 08:31
The only way I've found to reliably get the Versa to show you sleep stages in the morning is to use a wristband over the Versa and surrounding wrist areas at night. If you've worn the Versa all day, take it off and wash and towel dry your wrist vigorously before putting the Versa back on. Also rinse off the Versa, especially the back side with the sensors. You can thank @hoofbeats95 for the idea. It works, in contrast to most of the other suggestions posted so far.
04-02-2019 09:09
04-02-2019 09:09
Hello,
My Versa is not recording sleep or my heart rate, it's been that way for almost a week. At first I thought it was because I changed my watch face but that shouldn't matter. I've restarted the versa at least 3 times, I restarted my phone a few times and even went through and turned settings off then on again and it is still not recording them. I noticed yesterday that it is also not giving me my "reminder to move".
What else can I do?
Thank you.
12-01-2019 05:38
12-01-2019 05:38
I spoke with Fitbit customer service on 29 November 2019 about Fitbit no longer giving a sleep score. That's when I was told it wasn't tracking sleep stages. I just read a community input from 2018 addressing same issue. The comments were the same as those suggested to me 2 days ago. (I wasn't even aware of this problem.) Ironically, I'd already tried all the suggestions. Another thing is, I have not changed anything about the way I sleep; I have turned off Versa 2 numerous times; my battery isn't low. It's just that "all of a sudden, the watch stopped tracking my sleep stages, hence, no sleep score. This is a deal breaker for me. This problem was identified over a year ago, according to the Community, and it has not been resolved.
12-01-2019 07:04
12-01-2019 07:04
I have the same problem. My Versa stopped tracking sleep data on Nov 29. Not coincidentally, the app was last updated on Nov 29. I've tried all the suggested troubleshooting, and still nothing. I've tried manually logging sleep, but it shows no data for the hours I log.
12-10-2019 09:43
12-10-2019 09:43
Update: My Versa has started tracking sleep again, and it now shows that it was last updated on Nov 18. So I guess they rolled back the update that broke it.
01-08-2020 13:43
01-08-2020 13:43
Perhaps we have to complain in order for the sleep score to work. Consider this my complaint and I will see if it works tonight! I'll let you know!
01-14-2020 13:40
01-14-2020 13:40
Mine too. No heart rate or sleep since 29th but mine hasn't updated 😒
01-17-2020 13:11 - edited 01-17-2020 13:30
Any luck?
Best Answer01-17-2020 13:24
01-17-2020 13:24
Did it work? None of the solutions have worked for me. The sleep track feature stopped working 10 days after I got it as a gift last month. Fitbit seems to believe it’s a user issue but clearly it isn’t.
01-17-2020 14:33
01-17-2020 14:33
Not for me! Decided to get a new one as I'm fed up with the issues...the only thing it seems to be any good at is tracking the female cycle!
01-19-2020 06:21
01-19-2020 06:21
I posted my complaint on 1/8/20. As of 1/10/20 my tracker has been tracking my sleep stages. Was it the complaint that made it work...could be. I checked to make sure that I had renewed my premium membership (which I had for the year in September). I checked all my settings. Now the words Fitbit Premium appear on my Fitbit. I moved my band up the two fingers from my wrist and made it tighter when I went to bed and I changed my sleep sensitivity to Sensitive. Don't know what happened but whatever magic worked, I'm just glad it is working!!!!
03-13-2020 06:25
03-13-2020 06:25
Versa owners:
Some of us Inspire and Alta owners have had this problem return with the March 2 app update. (The same problem happened to us in January). Can you please let us know if your Versa is tracking sleep stages with the March 2 app update?
Thank you!
Best Answer03-13-2020 07:09
03-13-2020 07:09
Best Answer03-13-2020 07:19
03-13-2020 07:19
Thank you. This is good to know. There were some Versa owners that had problems in December and January. Maybe you were immune ...
Best Answer03-13-2020 19:12
03-13-2020 19:12
03-15-2020 06:21
03-15-2020 06:21
Thanks for this information. My Inspire HR seems to be working now but I may have to upgrade to a Versa if the sleep tracking continues to be a problem.
Best Answer04-26-2020 09:41
04-26-2020 09:41
I have read so many Q&A’s and tried everything recommended by Fitbit and others and nothing will work to make my Versa start tracking sleep again. It stopped on 3/2/20 and won’t track. I have tried all troubleshooting. Please let me know if it can be replaced even though I got it in 1/2/19. Very frustrated. Please help.
Best Answer04-26-2020 09:42
04-26-2020 09:42
Yes stopped tracking in 3/2/20. All troubleshooting has failed.
