How do I start and stop my strava app?
 How do I start and stop my strava app on my Versa Fitbit?
1 REPLY 1
The Strava app is only used to view your previous (historical) GPS tracked runs and cycling.
You will need to make sure your strava and fitbit accounts are linked. Then also go onto the fitbit app on your phone, tap the Account card in the top right corner of the screen, tap on your Versa, tap the app tile, make sure the my apps tab is selected, scroll down to Strava and tap the gear and then under Strava login tap on Strava Authorize. It should bring up a new page where you will enter your strava credentials.
To start tracking a workout on your Versa for it to show up in strava you need to select the exercise app on your device and choose either run or bike. Also tap the gear icon and make sure connected GPS is enabled.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
