05-04-2015 08:00 - edited 05-04-2015 08:53
Hello-
Our Medical Group is setting up Fitbit to allow our patients to submit readings to their online patient portal. I set up our FDI records and all was working except for when the patient would do the final step in connecting account- (although it was failing, the readings were still populating).
In an attempt to "fix" the issue, I reset our consumer key and secret. Now, when I log into our portal, i cannot even establish an account at all.
-Angela
Buffalo Medical Group
Best Answer05-04-2015 10:38
05-04-2015 10:38
If you reset your client (consumer) key and secret, you'll need to update your application with the new values before you'll be able to authenticate users or make API requests.
Best Answer05-04-2015 11:11
05-04-2015 11:11
Hi Jeremiah,
I did update that information on my application record. Still no luck.
Best Answer05-04-2015 11:45
05-04-2015 11:45
What request is failing and what is the error message?
