02-19-2017 11:57
02-19-2017 11:57
Can I link more than 1 fit zip to my Android phone? My husband and I both have fit zips, but he does not have a cell phone.
02-21-2017 13:12
02-21-2017 13:12
You just need to set it up with his email address. Has to be a new one and not yours.
You will need to log in and out all the time to check stats
Wendy | CA | Moto G6 Android
02-23-2017 03:57
02-23-2017 03:57
03-13-2017 13:32
03-13-2017 13:32
@Newtofitzip welcome aboard! @WendyB is so right. You just need to set up your husband's Fitbit Zip by creating a separate Fitbit account. You can set up multiple trackers to your Fitbit account but not from the same type, for example you can set up a Zip and a Flex; but not a Zip and a Zip.
Like @WendyB said as well, you will need to log in and out all the time to check a different account. Let me know if you have any other question about it. I'll be around!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
