12-07-2016
06:48
06:28
LanuzaFitbit
12-07-2016
06:48
06:28
LanuzaFitbit
Shouldn't the battery in my Zip last longer than 3 weeks?
Moderator edit: Clarified subject.
12-07-2016 07:50
12-07-2016 07:50
I moved this to the Zip Help Forum, @CathyKE7, where it will get more attention since it is specific to the Zip tracker.
Best Answer12-09-2016 00:40
12-09-2016 00:40
Make sure you are installing the battery correctly
Here is a youtube video to help
https://www.youtube.com/watch?v=Pmzz5df3CaY&t=6s
Wendy | CA | Moto G6 Android
Best Answer12-09-2016 10:31
12-09-2016 10:31
I've been having the same issue, it seems to be getting worse. I wish I had an answer for you/us.
Best Answer12-09-2016 10:32
12-09-2016 10:32
I'm having the same issue and it's getting worse. My battery is installed properly. Any other ideas? I've already reset it.
06:34
03:36
12-11-2016
06:34
03:36
A warm welcome to the Forums @Flitfloat! Thank you for moving this @USAF-Larry and @WendyB for chiming in to help.
@Flitfloat If you have already made sure that it is properly installed, I'd recommend that you get in touch with Customer Support. I'm sure they will be happy to help you and check on what's happening.
