05-15-2018
05:11
14:51
LucyAP
05-15-2018
05:11
14:51
LucyAP
I have had my Fitbit Zip a few months, and now the display looks as if it has been damaged. It is still working, but there is a large dark area in the center of the screen, so the only way I can check steps is on my phone, or online. Is this damage? Manufacturing defect?
Can it be reset to restore the screen?
Best Answer05-17-2018 14:49 - edited 05-17-2018 14:51
Welcome to the Forums @GMGC! Thanks for sharing your experience with your Zip tracker. This sounds odd.
Regarding your questions, I can't assure the cause of it because it may be damaged inflicted to the tracker or a manufacturing issue.
However, you can restart your Zip to make sure is working correctly. To restart your Zip, follow this helpful post.
I hope this helps, keep me posted! 🙂
Best Answer05-18-2018 03:58
05-18-2018 03:58
I performed a reset. Nothing changed.
Best Answer05-18-2018 11:28
05-18-2018 11:28
Thanks for the update @GMGC! I appreciate all the time and effort you have invested to solve this. To further assist you, I've created a Support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
