04-27-2018
00:42
14:10
LucyAP
04-27-2018
00:42
14:10
LucyAP
I have been having several problems with my zip.It keeps saying my battery is low when it has the correct new battery in. The most annoying thing is that I get up in the morning and it hasn't got rid of the previous day's steps. Any advice? jenn
Hi everyone! Thanks for stopping by! I appreciate that you have shared your experience with your Zip. This is usually a one time issue. However, to make sure that is working correctly please restart it.
Also, you might want to verify that there is proper contact between the battery and the battery contacts inside your Zip. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here.
I hope this helps, keep me posted! 🙂
Best AnswerAfter 3 days my zip reset itself and is working fine now. I tried taking the battery out overnight and it still didn't reset so I just left it alone and one morning I woke up and checked it and it was all zeroed out. I'm glad but mystified. 🙂
Thanks for stopping by @diesel and @justjannie! Thanks for sharing your experience with your Fitbit Zip. Upon checking with Support I was able to see that you have an open case with them. The best option at this moment is to continue working with them. I'm sure that they can help further with this.
@LeslieRo Thanks for sharing the troubleshooting steps you performed. Please let me know if you need extra help with this or if the issue persist.
Catch you later! 🙂
Thanks for your reply @justjannie! Great to hear that Support was able to help and you are back on track. Please post back if you need more help or if you have further questions.
Also, I'd like to encourage you to join us at the Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 🌸
Thanks for the update @diesel and @justjannie! 🙂 @justjannie Good to hear that you are on your way to crush all your fitness goals. I'd like to thank you for sharing the solution that Support provided. This might be beneficial to other users that may be experiencing the same issue.
@diesel Thanks for sharing that your tracker is working now. Regarding to the blank dashboard, I have a couple of questions:
Keep me posted! 🙂
Hey there @diesel! Thanks for the update and for all your feedback! I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
I'm really happy to hear that your Dashboard is working again. Now, regarding your Zip buddy. In this case, I would recommend checking the metal spring inside the Zip's battery compartment. Sometimes your tracker will have battery issues when this is bent. This process can be followed here.
Keep me posted with the outcome! 😉
