01-07-2020
00:48
04:22
JuanJoFitbit
01-07-2020
00:48
04:22
JuanJoFitbit
Is anyone currently having issues with battery draining on a Fitbit Zip? Mine is a real problem and currently the batteries are lasting several DAYS only! I previously contacted Customer support and my issue was not resolved they just said they weren't aware of this issue with anyone else using a Samsung Galaxy android phone. I have to get this sorted it is costing me an arm and a leg. Surely the issue isn't the phone anyway, the battery is showing empty on the actual Zip not just on the App.
03-30-2021
12:25
12:07
JuanJoFitbit
03-30-2021
12:25
12:07
JuanJoFitbit
@Ruralwriter can you substantiate your conclusion? As an engineer have you examined code from the app and determined that it's forcing frequent synchronizations or is this just unsubstantiated conspiracy theory? fortunately, for the rest of us, the simple fixes shared above resolve our problems. how does Fitbit generate revenue from a discontinued product? none of this makes sense to me.
"I picked the wrong week to quit drinking coffee" - Lloyd bridges, airplane
@LISKICKS what's happening to you too? happiness from resolving your battery issues? awesome!
I'll be back later, it's getting really weird here hahaha
Moderator edit: merged reply
03-30-2021 14:25
03-30-2021 14:25
Best Answer08-25-2021 02:09
08-25-2021 02:09
I've had issues with batteries only lasting 3-4 days since the last two app updates. I'm using a Samsung Galaxy S10 for synching. I have used both cheap (bought from Amazon) batteries, and name brand, Energizer, and having the same result with both. I have done the contact adjustments in the past, but not on every battery replacement. I couldn't tell you what the display shows, as I accidentally smashed it over a year back; but it still works. or at least it did. Since the last update steps have been greatly reduced. I enjoy using the zip as I can have it in my pocket at work (can't do that with most wrist based devices), considering a policy of not having items on the wrists and hands for safety reasons. It saddens me to find that the Zip has been discontinued. I have a Versa2 that I use outside of work, and I've had no issues with that.
I'll have to try the app uninstall/reinstall and see if that helps.
Best Answer08-25-2021 05:13
08-25-2021 05:13
Best Answer08-25-2021 07:00
08-25-2021 07:00
Best Answer10-14-2021 11:17
10-14-2021 11:17
I'm running into this problem too, I'm assuming that FitBit updated the firmware on the Zip to make it burn through batteries so people buy new devices since they don't make these anymore.
10-14-2021 11:29
10-14-2021 11:29
Best Answer10-21-2021 04:04
10-21-2021 04:04
I submitted a case for this issue since mine was draining in a day. Don’t suppose it’s been resolved?
Best Answer10-21-2021 06:20
10-21-2021 06:20
I'm afraid not. I can't even use mine since the battery drains so fast.
Best Answer12-19-2021 09:11
12-19-2021 09:11
I have the same issue, 4 batteries in the last week in a new Zip. Beyond frustrating.
12-19-2021 10:27
12-19-2021 10:27
Fitbit doesn't care about customers. And in a day or two this comment will be removed because it's "not useful."
Best Answer12-19-2021 15:44 - edited 12-19-2021 15:49
@SHORTIE1965 wrote:Is anyone currently having issues with battery draining on a Fitbit Zip? Mine is a real problem and currently the batteries are lasting several DAYS only! I previously contacted Customer support and my issue was not resolved they just said they weren't aware of this issue with anyone else using a Samsung Galaxy android phone. I have to get this sorted it is costing me an arm and a leg. Surely the issue isn't the phone anyway, the battery is showing empty on the actual Zip not just on the App.
Hi, since they have decide no one really want the fitbit zip, which of course is not true. They almost tripled the price and 2 whatever they did to the making of the fit bit was to discourage users. I have been ordering Amazon's batteries because they are much cheaper. But I know I will not purchase another product from fitbit. I like the zip. And they should keep it in functional order. I think it is poor business tactics for them to ignore the group of people that still want to use the zip..replacing battery every week, seriously. Before you could go 6 months. So why, where is there answer. They refuse to give any ...They just decided to faze it out and this is how.. Triple the price and it's working condition is ridiculous.
12-19-2021 15:55
12-19-2021 15:55
Yes, I did the same bought from ebay, the first one I bought at Kolhs for 60 bucks. Now 120.00. It's more expensive and constant battery change. But it is the most convenient tracker for me. Hate when you enjoy a. Item and they discontinue..
12-20-2021 16:01
12-20-2021 16:01
12-20-2021 16:05
12-20-2021 16:05
Very glad to hear you like your Inspire 2 as I'm getting one for Christmas. I got tired of replacing the batteries but still wanted something I could clip into my pocket. And it was on sale so not too bad of a price - comparable to the Zip I bought years and years ago. Thank you for sharing.
12-22-2021 07:11
12-22-2021 07:11
Hi, So what happens when they decide to discontinue another item do they do the same thing. I thought about buying another item but that was my concern. I don't have the same confidence in them. If they cane straight out and said it was going to be fazed out that would ve one thing. But they didn't. So how do you trust when and which product they decide to do next.😌
01-03-2022 09:37
01-03-2022 09:37
Yes I have the same problem with my Android. But I have lifetime replacement with Batteries Plus so not costing me for replacement, just annoying.
Best Answer03-31-2022 19:22
03-31-2022 19:22
Something must have changed at end of January because the drain had stopped for a long time but now it’s back where my battery lasts 1 or 2 days. App says battery full but getting the no battery icon on the zip. I will use up the batteries I bought but then if the drain is still happening I am done with it. Won’t get a watch - don’t want something on my wrist which is why I have the zip.
03-31-2022 21:36
03-31-2022 21:36
04-01-2022 21:30
04-01-2022 21:30
having this problem exactly, but I’m not sure it’s true I’m getting email messages saying my battery‘s drained after a couple days or a week but if I ignore them it continues to work and I thought I saw somewhere that my battery actually did have a charge. I thought it was on the app itself but I can’t find it now
