Best AnswerKittens are weird. Can't help you with that problem 🙂
I think your phone is compatible, and will continue to be compatible. I am running Fitbit Connect on an old Galaxy Tab 2 10.1, Android 4.2.2, from April of 2012, and it still works fine. Your phone is relatively modern, from December of 2014.
Did the kitten ever crack the case or display, or open the Fitbit up? If not, I don't think kitten can be blamed. Zips are pretty tough devices.
How long have you had the Zip?
Are you in the 45 day warranty period?
Are you in the one year warranty period?
I have a bunch of specific Zip/computer questions, though. Answer as many as you can:
1) on you phone, what version of Android are you running?
2) on your phone, do you allow google play to auto-update your apps?
3) on your phone, if you auto-update, is it wi-fi only, or any time?
This web page can help you answer those questions:
https://support.google.com/googleplay/answer/113412?hl=en
4) on your phone, what version of the fitbit connect app are you running (2.15.1?)
5) on your Zip, what version of firmware are you running?
The version number is the first thing the Zip displays when you put a battery back in, before the smilies.
6) On the iPad, what version of Connect is running?
7) On the iPad, have you ever in the past successfully synced your Zip?
😎 on the Windows 10 machine, what version of Fitbit Connect is running?
9) on the Windows 10 machine, did you use the little USB plugin that came with your Zip?
10) on the Windows 10 machine, have you ever in the past successfully synced your Zip?
Hello @SuziSenior, welcome aboard to our Community and I'm sorry to hear your Zip is not syncing. Also @SunsetRunner thank you so much for helping on this, actually these are great questions to find the source of the issue.
Since on the original post @SuziSenior you mentioned about contacting support, I took the liberty to reach them and according to the information you sent to them along with the details you provided here, It seems your tracker is not pair to your account. Which will explain why your timezone is not correct and is not resetting at midnight. So beside the details requested above I will add to the help to try to pair your tracker again with your existing account.
Keep in mind it has to be with a supported device. In either case, I shared a post a while ago with the steps to pair your tracker using your same account. Please take a look at this link for more information.
Lets try this and let us know how it goes. See you around!
Best AnswerHi,
Thank you so much for getting back to me. Yes, the kitten is weird but we do love him!
Please find my answers below!
How long have you had the Zip? It was a Christmas present this year so it is 9 Months old.
Are you in the 45 day warranty period? No
Are you in the one year warranty period? I don't know as didn't purchse this Zip
1) on you phone, what version of Android are you running? 5.0.2
2) on your phone, do you allow google play to auto-update your apps? Yes I do.
3) on your phone, if you auto-update, is it wi-fi only, or any time? Wi-Fi Only asd I never turn my data on but I have tried to get the Zip to connect using both.
4) on your phone, what version of the fitbit connect app are you running (2.15.1?) 3.9
5) on your Zip, what version of firmware are you running? I can no loger see this. When I take the battery out no code is displayed and it goes straight to smilies.
6) On the iPad, what version of Connect is running? 3.9
7) On the iPad, have you ever in the past successfully synced your Zip? No, I only got the app when the zip started to not sync with the phone. I have never been able to pair it of sync it with the Ipad.
😎 on the Windows 10 machine, what version of Fitbit Connect is running? Latest version available as I downloaded it to see if I could get the Zip to work.
9) on the Windows 10 machine, did you use the little USB plugin that came with your Zip? Yes
10) on the Windows 10 machine, have you ever in the past successfully synced your Zip? No, I have never used it before. I have tried on 2 different windows 10 machines.
Thank you so much for your help so far.
Suzi
Best AnswerHi,
I was advised by support to remove the device and re add it. Now I cannot get it to re-connect with any of the devices I have tried to use hense there is no Zip paired to my account!
I have tried on several different devices to get it to see and connect to my Zip.
Thanks
Suzi
Best AnswerSorry, you also asked what damage the kitten had done. He has scratched the screen with his teeth but you can still see the numbers and in the top right hand corner he has put a tooth into the plastic so there is a pin hole but I don't believe that it has gone all the way through to the screen.
Hi @SuziSenior - It appears that you are still within the 1 year warranty period. You have done a lot of troubleshooting and it seems that you are still unable to connect your Zip. I would get back in touch with support - help.fitbit.com - I am guessing that your tracker is faulty. Good luck!
I think that since display it still working, the scratch really isn't the issue... But not my call!
Hi there @SuziSenior and welcome aboard to our Community @Wolke.
@SuziSenior were you able to received more assistance from our Support Team?
I wonder how it goes for you @Wolke? if you are experiencing the same issue, please refer to this post for more help in case you haven't tried these suggestions: Having trouble syncing? (here's how to fix this).
Keep me posted in case you need more help. I'll be around.
