Hello @Rickyj37, glad to see you in the Forums! My recommendation is to take the battery out the Fitbit for a few seconds and put it back in. If this does not work, please try to change the battery to a new one and see if this helps. If after the previous steps the Fitbit is still idle, please contact our Support Team so they can check in the system why is this happening and give you the best solution for this matter.
Keep me posted with the outcome! ![]()
What's for breakfast?Check others recipes and share yours!
Hey @Rickyj37, awesome to see you again! I'm glad to know that you're getting a Fitbit to get you back on track, once you get it set it up with your account and everything should be working properly. I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members.
I'll see you around the Community! ![]()
