12-31-2013
15:41
10:41
HelenaFitbit
12-31-2013
15:41
10:41
HelenaFitbit
I can't remove the battery door on my Zip using a coin. Attempts have already caused some damage to the coin slot. Any ideas about how to proceed. Thanks...
01-06-2018 12:56
01-06-2018 12:56
I have tried all of these suggestions and none of them work, the door won't open. The back is now so damaged that a coin won't fit anymore. I guess i just blew $60 for nothing. So frustrating.
01-06-2018 14:40
01-06-2018 14:40
01-07-2018 09:33
01-07-2018 09:33
Best Answer06-03-2018 16:18
06-03-2018 16:18
Got this product few years ago in my company, did not try to use it until today. I also cannot open the battery door. Door opener/tool does not work. I also tried with a coin (a quarter), with the same result - door just does not rotate into unlocked position. Then I tried your trick with a towel and hammer, multiple times, and nothing happens. Absolutely disappointed ...
Best Answer06-05-2018 07:36
06-05-2018 07:36
Welcome to the Forums @EStrah! Thanks for sharing your experience with your Zip and for the troubleshooting you tried before posting here.
Please confirm that you have tried to open the Zip's battery following these steps:
I look forward for your reply! 🙂
12:09
16:22
LucyAP
06-07-2018
12:09
16:22
LucyAP
I cannot remove the battery door either. This is beyond frustrating. I have used the tool that comes with it but the arrow will not get all the way to or even past the unlock icon. Where do I go from here?
Moderator edit: format
12:12
16:18
LucyAP
06-07-2018
12:12
16:18
LucyAP
Mine is in the junk drawer. It’s not usable without a new battery. And I can’t get the door open.
Laine Bryce
Moderator edit: personal information displayed
06-07-2018 15:30
06-07-2018 15:30
Try using a hair drier for about 30 seconds. It worked for me.
06-09-2018 10:00 - edited 06-09-2018 10:05
Welcome @pamdaber, @lbsch5711, and @EStrah! Thanks for sharing your experience with your Zip. I wanted to assure you that we take into consideration all the comments provided by our users to continue improving your experience.
@pamdaber, and @lbsch5711 To further assist you, I've created a Support case on your behalf. You should receive an email from Customer Support at the email you used to register with the Community forums. I'm sure that they can find a way to help. In the meantime, please make sure to check out our Warranty Policies.
@EStrah I'm sorry to hear that Zip is not the right fit for you. I appreciate all your feedback this helps ups to keep improving our products and services. I hope in the future you give us an opportunity to help you on your fitness journey.
Keep me posted if you have any other question.
Best Answer07-06-2018 20:06
07-06-2018 20:06
So...I lost my Fitbit 3 or 4 years ago and just found it in a pants pocket! Yay! Surprisingly, I couldn't open it with a quarter, and thought the battery had corroded it shut. I read all the responses here - surprised there's a "tool" - have no idea where that would be. Tried the hammer, hitting it harder and harder since I don't think I'm going to get this thing to ever work again anyway. As a last resort, I tried the hair dryer and it worked!! Bingo!
07-11-2018 13:33 - edited 07-11-2018 13:35
Nice to see that you're digging into the Forums @LizzybethC, let me give you a warm welcome to our Community. ![]()
Thanks for sharing your experience! Wow, what an odyssey to open your Zip. So glad that you found it in your pants. Is this working okay? I'm eager to hear the outcome of your story. ![]()
See you around.
Best Answer07-26-2018 12:38
07-26-2018 12:38
The hairdryer method absolutely works!! I also couldn't open my Fitbit Zip to change the battery. Tried coins and a flathead screwdriver. That didn't work but it did damage the plastic slot. I hadn't used my Zip in so long that I had forgotten it came with a tool for opening the back (Thanks to the previous posts for mentioning it!). The tool worked....but only after I used the hairdryer for about 30 seconds. I was almost ready to toss the Zip....so glad I didn't.
07-27-2018 08:59
07-27-2018 08:59
Hi, YojanaFitbit - thanks for checking back. I changed the battery, it seemed to work for one day, then died. So disappointing. I haven't thrown it away yet, but I'm afraid it's a lost cause.
Beth
07-27-2018 09:04
07-27-2018 09:04
interesting you should mention that. my batteries were dying pretty quickly so i bought a bunch of CR2025 batteries from Amazon, Sony brand and about 1/2 of them are either dead already, or die in a day or 2. i've had a couple last the usual 2 or 3 months but not many.
07-29-2018 09:08
07-29-2018 09:08
Hi @CCT74, welcome to the Forums! @LizzybethC and @Steveski, nice to see you again! ![]()
WoW!
That's a really great workaround @CCT74, not sure if it will work in all cases but it's definitely possible you will help other users that might be having similar issues with their Zip. I hope you can keep using your Zip for long time! Thanks for sharing this with us.
@LizzybethC and @Steveski why don't you try some steps to clean your Zip contacts? That might help. I'd like to know what model of phone are you using too.
Let me know if this helps. ![]()
Best Answer09-06-2018 04:26
09-06-2018 04:26
A tool that works quite well to remove the battery door is a Channel Lock S5388CB 3/8 inch flathead screwdriver. It fits the slot in the door perfectly. The screwdriver is fairly large so it won't get lost easily. It costs $5.99 at Amazon . As a screwdriver it is a very useful tool so your money will be well spent. Lay the Zip face down on a towel, hold it with one hand to keep it from turning, press lightly down with the screwdriver located in the slot on the battery door and rotate the door counter clockwise. Note that there are detents that prevent the door from coming open while you are jogging and the door must be gently pressed down a bit to clear the detents before you can rotate and remove the door. Remember that you can buy batteries in bulk, 10 or more to a package very inexpensively from Amazon.
09-06-2018 07:05
09-06-2018 07:05
Thanks for the tip Sparky! 🙂
09-07-2018 11:48
09-07-2018 11:48
Hi @SparkyO, thanks for sharing this information with us. As @Steveski mentioned, it's a great tip. Some users have also mentioned that using a coin is really helpful when you don't have the door tool.
Let me know if you need further help with your Zip.
Best Answer09-07-2018 12:58
09-07-2018 12:58
i can't say enough tho that you should NOT use a coin, ever. that seems to destroy the thing. seems like a coin should do the trick but it DOES NOT. please don't use a coin.
09-07-2018
13:12
10:02
YojanaFitbit
09-07-2018
13:12
10:02
YojanaFitbit
Using a coin to remove the battery door on a Fitbit Zip is like trying to
fit a round peg into a square hole. You may get it to work but you will do
it some damage.
Because of its round shape a coin will not make proper contact with the
sides of the square (OK, Rectangular) slot in the battery door and the edges
of the slot will get chipped away and you will very likely quickly reach the
point of no return with too much material chipped away.
A Channel Lock S388CB 3/8 inch Flat Head Screwdriver, $5.99 at Amazon, fits
the slot well and should not cause any damage to the battery door.
What you save buying the batteries in bulk will pay for the screwdriver.
