12-31-2013
15:41
10:41
HelenaFitbit
12-31-2013
15:41
10:41
HelenaFitbit
I can't remove the battery door on my Zip using a coin. Attempts have already caused some damage to the coin slot. Any ideas about how to proceed. Thanks...
05-18-2019 09:54
05-18-2019 09:54
So, approximately 10 months later.... I just purchased a fitbit zip and have become one of the multitudes who can't get the back off to insert a battery. I tried 4 different coins and that "tool" and a screwdriver. Maybe if I just stare at it like a cat? Yes I'm extremely annoyed.
05-18-2019 09:58
05-18-2019 09:58
If the tool won't open the door, try using a blow dryer and blow on the door for about 10 seconds. If it won't open, try blowing a little longer. My friend gave me a fitbit zip that she wasn't using but I couldn't get the door to open. I tried this method as suggested by some on the board and it worked the second time.
Good luck!
05-18-2019 10:01
05-18-2019 10:01
I just ordered it from Amazon. Thanks!
05-18-2019 10:05
05-18-2019 10:05
05-18-2019 10:35
05-18-2019 10:35
In the end, i looked at a YouTube video and figured out that it has to be held in one hand. I had it on a hard surface. I got the back off with the "tool" (I insist on putting quotation marks around "tool" because IMHO it's an absurdity.)
05-21-2019 16:19
05-21-2019 16:19
Using a hairdryer worked for me too! Thanks for the tip.
07-31-2019 07:42
07-31-2019 07:42
I used a suction cup and it worked after denting the back for hours !
01-18-2020 11:17
01-18-2020 11:17
I used the hair dryer method & it worked perfectly with the tool. I wish I could find another back. I have a perfectly good fit bit zip but the back piece crumbled while trying to get the back off with a screwdriver.
01-22-2020 20:39
01-22-2020 20:39
....Same here. Wife lost her Zip-tool, and nickels, quarters, 1/2 width screwdrivers were no use.
Tried the hair dryer for 30-some odd seconds...bingo, opened right up with a nickel.
Thanks Community!
05-09-2020 12:28
05-09-2020 12:28
Mine still isn’t working
11-04-2020 11:22
11-04-2020 11:22
I also faced the same problem. However, I have tried to get some solution for it.
11-09-2020 06:41
11-09-2020 06:41
Has anyone tried creating this 3D replacement battery door for the Zip? https://www.stlfinder.com/3dmodels/fitbit-zip-replacement-battery-cover/ I've got 4 zips without doors and interested if anyone's tried this. I don't have a 3d printer, so would likely have to pay a premium for one of those on-demand services, but surely I'm not the only one needing a door or a battery tool.
11-09-2020 09:25
11-09-2020 09:25
I feel your pain I finally found the right coin to get it to open.
01-29-2021 21:02
01-29-2021 21:02
@alexjohn did you mean to link to a proper Zip tool you've successfully used? Your link went to some cardboard tube company. I'm using a 3D printed recreated back cover (linked above) and tool as had a ZIp without either.
if anyone uses heat to open a stuck back, just be quick to not damage the circuitry.
3D Recreation of Fitbit ZIP Tool
04-09-2022 21:06
04-09-2022 21:06
Hair dryer worked! I didn’t have any thing to loose by trying it! I have been trying to get that cover off for years!
04-26-2022 22:07
04-26-2022 22:07
Thanks for posting. I just tried the hair dryer after trying everything else and it worked.
02-26-2023 14:53
02-26-2023 14:53
Thank you for sharing this! The hairdryer trick worked for me!
02-26-2023 15:56
02-26-2023 15:56
I’m glad this hint is still working!!
04-21-2023 16:40
04-21-2023 16:40
Lay it down on a towel then heat up the back with a hair dryer. Use a nickel to open it up. Just replaced the battery on a Zip that's been in a drawer for 4 years and this worked like a charm! Now, to see if I can get it to sync.................lol
04-24-2023 11:47
04-24-2023 11:47
I also would like to know what coin
