08-19-2017 20:00
08-19-2017 20:00
My zip is showing miles instead of steps. How do I Change that?
Best Answer08-21-2017 19:57
08-21-2017 19:57
Thanks for stopping by @Sugarbell! This sounds odd. To make sure that your tracker is working correctly, please restart it. If this is not working, set it up as a replacement device.
I hope this helps, keep me posted! 🙂
Best Answer08-27-2017 01:53
08-27-2017 01:53
Yes talked to costumer help and that guy Walked me through on how to fix it. All is well now. Thanks
08-28-2017 19:08
08-28-2017 19:08
Thanks for the update @Sugarbell! So good to hear that you are back on track. Let me know if you have more questions.
Also, I'd like to encourage you to join us at Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more!
Give it a look! 😉
