05-26-2017 11:51
05-26-2017 11:51
A couple weeks ago I noticed my zip was not accurately counting steps all of a sudden. It'd say I had gone 200 steps but 1.1 miles. Then I'd sync it and it would go up to 1650 steps and 1.5 miles. Then 2 minutes later when I check it would say I've gone 1620 steps and 1.5 miles.
The last 2 days it's barely measuring any steps. I should be around 3k or more so far today and it said 40 steps. I synced it to phone and it updated to 400 steps. I need to accurately measure steps for my doctor and this is really screwing things up.
I have already followed suggestions and checked the battery placement, took battery out and reinstalled, etc multiple times over the last few weeks trying to fix this. Nothing has helped. The way I wear it hasn't changed, ever. So that's not the issue. I wear it in my small 5th pocket on my jeans. Just incredibly frustrated and disappointed with this.
05-27-2017 15:02
05-27-2017 15:02
You didn't mention if you had replaced the battery: you only mention "re-installing". If you have not installed a new battery, go ahead and try that. A weak battery could explain the problems you are having. I have never had a battery fail without either the app or the Zip telling me about it, but I can't say that it never happens.
Like you mention, make sure your battery tabs are in good shape. If you ever look at your zip and see a 5.86 in the display, you know you have some kind of battery problem.
05-28-2017 09:43
05-28-2017 09:43
@SnnysAngl I hope you're doing well! Like @SunsetRunner said a weak battery could cause these issues but also make sure the battery it tight within the tracker by pulling the towards you so it secures the battery inside. Also clean the contacts with a cotton swab and rubbing alcohol before adjusting the tabs (refer to the pictures to secure the tabs).
Let me know how it goes!
