11-11-2017 06:31 - edited 11-11-2017 06:33
Hi
My fitbit zip wont sync i have reset the zip,changed the battery and also checked the metal clip.
But it still wont sync.
Does anyone know why?
Thank you
Best Answer11-11-2017 10:05
11-11-2017 10:05
Hello @Dawngamo
How are you trying to sync - computer or mobile device? Try turning off and then on, the device to see if that helps. With a smartphone, turn off bluetooth, then restart the phone and turn on bluetooth again. See if that helps.
Let us know.
11-11-2017 10:12
11-11-2017 10:12
