04-26-2018
16:43
11:59
LucyAP
04-26-2018
16:43
11:59
LucyAP
The cover to the battery compartment is so tight I can't get it off. Any suggestions? Am missing a step before taking the cover off?
Best Answer@randigbis it a new Zip? If it's one you bought locally, you might be able to take it to the retailer and have them help you.
Sometimes when a flashlight is giving me difficulties and needs fresh batteries, I take it to a battery store and have them open it for me.
You can check with customer support to see if there is any trick they might have - click to go there
Hi @randigb
There is no special step to take before removing it. You using the provided tool or a dime to open it? Sometimes it does take a bit more to get it open.
I've tried the tool, a dime, a screwdriver, a knife. None have worked. Guess I'll just keep trying.
Awesome suggestion @Odyssey13! Welcome to the Forums @randigb! So good to hear that you are back on track.
I have gone ahead and marked @Odyssey13's as an Accepted Solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member facing the same questions or issues as you. You can read more about Accepted Solutions here.
I hope to see you around more often!
