07-05-2017
02:03
19:36
LucyAP
07-05-2017
02:03
19:36
LucyAP
Got my zip on June 2, 2017. Had to replace battery on June 23. July 4 I went to check my numbers for the day and its dead again!! How long is the battery supposed to last on these things?? I have really enjoyed having my zip but don't think I want it if I have to change the battery every couple of weeks!
Moderator edit: format and title for clarity
Nice to see you here @tlafond! This sounds odd. To ensure that your tracker is working correctly, please restart it. Also, you can check the inside spring. Sometimes your tracker will have battery issues when this is bent. You can check this post by @vomitofthemind to see the steps on how to check the correct placing of your Zip's metal pin.
I hope this helps, keep me posted! 🙂
