07-04-2017
11:53
18:20
LucyAP
07-04-2017
11:53
18:20
LucyAP
Fitbit stopped showing anything but zeroes for steps, calories, distance. Only showing time. Replaced battery. No change. Any ideas?
Moderator edit: title for clarity
It's great to see that you've visited the Fitbit Community @nitrodave! This sounds odd. To ensure that your tracker is working correctly, please restart it. Also, check the metal spring inside your tracker to make sure it is in the correct place. To do so, check the post of @vomitofthemind about Zip not responding after changing the battery.
I hope this helps, keep me posted! 😉
