03-04-2018 10:04
03-04-2018 10:04
I was asked to uninstall Fitbit zip and reinstall, I did that now it is not connected
Best Answer03-05-2018 14:46
03-05-2018 14:46
Welcome back @justjannie! Thanks for troubleshooting steps you performed before posting here. Usually a missing requirement is the cause that you tracker is not able to communicate with the Fitbit App.
If you are not able to setup your Zip, you can follow the help article Why can't I set up my Fitbit device? Or, if you are having difficulties to sync your tracker, visit the help article Why won't my Fitbit device sync?
Keep me posted with the outcome! 🙂
03-08-2018 06:49
03-08-2018 06:49
Best Answer03-08-2018 13:43
03-08-2018 13:43
Thanks for the reply @justjannie! This sounds weird. In this case, I would recommend checking the metal spring inside the Zip's battery compartment. Your tracker will have some issues when this is bent. You can take a look at @vomitofthemind's post to see how to fix your bent battery.
Also, make sure that your tracker is up to date. To do so, take a look at the help article How do I update my Fitbit device?
I hope this helps, keep me posted! 🙂
Best Answer03-08-2018 15:56
03-08-2018 15:56
Best Answer03-09-2018 03:32
03-09-2018 03:32
Mines stop syncing on Monday as well. Did anyone get any answers to resolve the issue?
Best Answer03-09-2018 03:37
03-09-2018 03:37
Best Answer03-09-2018 03:44
03-09-2018 03:44
Best Answer03-09-2018 03:55
03-09-2018 03:55
Best Answer03-09-2018 08:11
03-09-2018 08:11
Awesome help @justjannie! I'll continue assisting you in your other post Installed Battery and now not syncing and wrong time. Please let me know if you have further questions.
Welcome to the Forums @Soniaaponte85! Thanks for sharing your experience with Fitbit. In this situation, I'd like to suggest you to restart your Zip and make sure that your app is up to date. To do so, take a look at the help article About the Fitbit app.
Please keep me posted! 🙂
Best Answer03-09-2018 16:52
03-09-2018 16:52
Best Answer03-10-2018 07:47
03-10-2018 07:47
Thanks for the update @justjannie! Great to hear that your tracker is working fine. If some steps are missing and you remember the amount, you can manually log them.
To do manually log steps you can follow the tips from this post. Please feel free to post back if you need more help or if you have more questions.
Catch you later! 😉
